I had to laugh when I photographed these pieces of clay. I asked if he cut a hole in the bottom of a bowl and then tried to save it by make a larger vessel. I sure does look that way. What do you think.
One of my clubs meets in a wood shop next door to a pottery classroom that has classes most of the same evenings. One thing I've learned is that the way clay is worked is totally different than what we do with wood. This was made from the bottom up, a portion at a time. Probably the bottom part first, then middle third or so added, then the neck. The artist didn't have to 'hollow' anything out like we do - wet clay can be stuck together bit by bit.
Funny you post this today John. My wife is a potter and we went to a presentation last evening by a well known potter from Kansas City who uses a technique very similar to this photo. The person whose piece you shot may have even learned it from the guy I met last night (he has been teaching it for a few decades). Very nice piece here. It was probably thrown in more than 1 piece and assembled as Walt said. The middle section has a thinner liquid clay called slip that is added and textured while wet. Pottery is mostly an additive process where you can add on more when desired where woodturning is mostly a subtractive process. Clay is a lot more flexible than wood when being worked. I'm a little jealous of the potters. When they make a mistake they just mash it up and throw it in the slop bucket to be used again. Our mistakes are much less forgiving.
I give a lot of my chips to potters who do Raku style firing.
One of my clay friends says our process is all negative, we are removing material all the time. Discounting segmented work of course. Clay process are usually positive or adding material
Subtractive procedures are actually quite common in pottery production. Many of the ancient assemblages I've worked with frequently include cutting away clay. One common process is to invert a leather-hard bowl (thrown with a thick base) on a wheel, and cut away clay as it rotates to produce a ring base -- just as is done in woodturning. In the Persian-Hellenistic pottery I've worked with, most bases on smaller vessels were finished this way. Many other pottery turning processes in various assemblages involve cutting away clay, often while the vessel is rotated at slow speed on a turntable, or at higher speeds.
R. Henrickson-what you describe is a common trimming process for establishing a distinct foot for the piece. And you are absoultely correct about the subtractive aspects of pottery. That is why I qualified my statements with "mostly". Lots of potters build up pieces and then cut away what they don't want. I wish wood was as maleable as clay. Maybe I should just switch to clay. ;-)) We already have a complete studio at home.
John-I also understand that perspective. Sort of makes me feel like they don't think very highly of what we do with wood. Potters are a lot of fun though-in my experience.
