Over the weekend I picked up a couple of big leaf Maple logs, from a tree recently cut, but the tree has been dying for the past couple of years. When I cut into the logs there was a blackish-grey stain all around the edge of the logs penetraiting in a couple of inches. Is this stain from the bark or is it some other bug? Will it stop spreading now that I have cut the logs into small pieces and sealed the ends? The bark is still tight in most places. Am I just storing future fire wood?
I would tend to agree, either spalting (fungal infestation) or perhaps mineral staining, but it might not be all that pretty when finished -- let's hope it turns out great!
The sapwood in some species tends to turn gray if left to sit around too long -- doesn't happen when turned right away. Sapwood in some species contains a lot of sugars, and under the right conditions you can get beautiful spalting, or sometimes just dull grey blah. Maples tend to have high sugar content in spring, and the sapwood "stores" better if cut in fall or winter.
The beautiful cream-colored sapwood of Black Walnut tends to go grey, as do the Maples, White Pine (called bluing), and some species, such as Am. Sycamore, should be "end reared" when seasoning to avoid this sort of mineral stain.
