plummers friend
plummers friend
plummers friend
This is why I like my lathe. I had to repair my toilet this weekend and it had a piece I had never seen before to screw it together. It took about 15 minutes of cussing with channel lock pliers expanded into the open nut and a screwdriver as a lever to twist the plastic ring out. I kept thinking I would break off the little flanges that you grip.
I went to Lowes to get the parts and the didn't have anything like it and didn't have the tool to install and replace the nut either. I was able to buy enough parts from other kits to repair the old unit. I went into the shop and in about 15 or 20 minutes made this tool that worked perfectly for installing the nut.
Re: plummers friend
Hmm
Aren't those connectors supposed to be only hand-tight? Nice solution, though. Whatever it takes is always my motto.
Re: plummers friend
Re: plummers friend
Ellis It's a large plastic flange that is threaded on the outside and only has 4 thin plastic ridges to grip to remove it. It compresses a large rubber "0" ring so hand tight was apparently enough.
Re: plummers friend
Re: plummers friend
Galen Vetterick
At plumbers wages that's still one expensive tool! :D
Re: plummers friend
Rob Wallace
Re: plummers friend
Rob Wallace
John:
Were you required to expose the top of your butt while doing this repair? :D
Rob
Re: plummers friend
jim miles
Re: plummers friend
jim miles
May be you can sell it to Lowe's
Can you make 10,000 ?
