I am interested in trying epoxy thinned with aceone or lacquer thinner as a finsh. I've read a little about it but have some questions for any of you with experience with it.
1. Mix up the 2 part epoxy in a small container and add the thinner...How much thinner should one use?
2. How long should one let it cure before next coat?
Both Devco 2 Ton epoxy and Enviro Tex light are commonly used as clear coats (gloss) over turned striped bass plugs made from Cedar, Maple, Birch, an Mahogany. They can be thinned but I prefer to warm up the 2 bottles in warm water prior to mixing them 1:1
The 2 Ton Devco epoxy sets up much faster and does not require a spinner to prevent sags. The Envirotex Light is a thinner product and requires a rotating mechanism to obtain a uniform thickness... it sets up in about 45-60 minutes while the Devco sets up in 15-30 minutes. the working time can be prolonged by mixing on a piece of aluminium foil or on a qt yogurt top as the mixing surface... mix with a 3/8" diameter dowel... it introduces less bubbles... some people use a candle to remove the occasional bubble that may be present... the bubbles are made by the polymerization rxn and a small mt of heat... even your breath will pop the bubbles.
Epoxy is usually applied with an acid brush available in craft stores... to eliminate the troublesome shedding of the bristles ... add a small amt of superglue where the bristles meet the metal handle
I have used epoxy as a finish on small bowls, ice cream scoop handles, and turned and hand carved striper plugs
Just be aware that epoxy is sensitive to UV light. Depending on the end use of the piece, it may not matter, but anything displayed where sunlight is present is not likely to look good forever.
