spraying stuff
spraying stuff
spraying stuff
darrin hill
starting to think about doing a spraying finishing area. Any input?
As far as i know, it's putting pvc pipe everywere and t joints where i want to drop a hose...
do i need a regulator at each station? A regulator just keeps it from being too strong, right?
I want an airbrush area, but also drop hoses every 6-10 feet in case i want to use something there.. like pnumatic air tools or something.. and to be able to blow out hollow forms would be great..
Re: spraying stuff
Re: spraying stuff
Stanley Townsend
Please don't use PVC for pressure air lines, they EXPLOAD VIOLENTLY!!!!
Re: spraying stuff
Re: spraying stuff
darrin hill
everyone i know of has theirs in pvc pipe..
1/2 inch schedule 40...
and they've been using their compressors for decades...
Re: spraying stuff
Re: spraying stuff
Bernie Weishapl
I agree with Stanley and wouldn't use PVC. My shop is now plumbed with copper pipe. Fortunately I wasn't in the shop when my schedule 40 exploded.
Re: spraying stuff
Re: spraying stuff
darrin hill
k... kinda expensive though... didnt know it was that bad... Everyone i know has pvc..
Re: spraying stuff
Re: spraying stuff
mjonesrdg
For an airbrush application, sch.40 might be adequate, but imagine any compressed air process that you might want to employ such as..." blowing out hollow forms"... that exceeds 40 psi, and you'll need to use galv. pipe. PVC is not made for compressed air.
Be safe!
Mike in Redding, Ca.
Re: spraying stuff
Re: spraying stuff
I've seen evidence of a PVC explosion also. I would not recommend it. I am currently using flexible hoses. I simply put a tripple connector on my compressor and ran flexible hose to 3 parts of the shop. It was supposed to be temporary but that was 5 years ago. Hope to change to pipe one of these days when I finally decide how my shop should be layed out.
Re: spraying stuff
Re: spraying stuff *LINK*
Stuart Johnson
Darrin, I don't know any numbers but assume (I know the danger in that) p.v.c. exploding is rare. However, rare doesn't mean safe and you have twins that need safe. Spend the bucks and go with copper, galvanized pipe or like John air hoses if you want to postpone the expense. There are enough risks just getting out of bed without adding avoidable ones.
OSHA and PVC
Re: spraying stuff
Re: spraying stuff
Don't use PVC pipe. Compressed air has a lot of stored energy and when it fails the pipe could become shrapnel and put and eye out or worse.
Re: spraying stuff
PS... Another Reason not to use PVC
If you leave your compressor ON so that you have compressed air always available and he line bursts while you are not there, the compressor will run until you get back. Murphy's Law says that will be while you are on vacation and the compressor will over heat and set the place on fire.
Re: spraying stuff
Re: spraying stuff
jerry bennett
Darrin, I would suggest considering some kind of spray booth with means to evacuate the spray as a part of your research. Of course you can use a respirator just fine. There are some major health risks associated with spraying. I apologize if you are already up speed on all of this. When I started, I made all of the mistakes and did not leave any out. :( It cost me more in the long run.
Re: spraying stuff
Re: PS... Another Reason not to use PVC
Wally Dickerman
That's the reason I unplug just about everything in my shop if I leave for more than a day or so. Especially the lathe with it's electronic controls. I always unplug the lathe after using it during our monsoon season with it's almost daily thunderstorms..
Re: spraying stuff
Dennis in Southern Oregon
Re: spraying stuff
I plumbed my shop with copper air lines for this same reason. As I recall 1/2-inch copper was about $10 per 10-ft joint and was not the most expensive part of the project.
Dennis
Re: spraying stuff
Dick Hines
dick hines
I put a ball valve on my compresser so it will not leak down. I turn off the power and the ball valve every time I leave the shop.
Re: spraying stuff
Re: spraying stuff
darrin hill
so other than copper pipe, (and now i have to learn to solder...) what else? just fittings? do i need a lot of regulators?
Re: spraying stuff
Re: spraying stuff
Darrin I'm not sure where to tell you to look but there have been some excellent articles in the various woodworking magazines on running air in your shop. Maybe a google search will bring up something. They tell you about pipe sizes, drops for moisture release, valves etc. I've read them but alas so far haven't done anything but rubber hose and a regulator just before the spray gun.
I do have a new (to me) large air compressor that I had planned to install this summer but haven't had the time and money at the same time to run a new 220 line to the shop which will be necessary to run this, the larger dust collector I'm saving for and my new to me welder.
Re: spraying stuff
found this  *LINK*
http://www.webbikeworld.com/t2/compressed-air/
Re: spraying stuff
Re: spraying stuff
Walleye Guy
I second the Rapid Air kit!
