Thinning water-based to wipe on?
Craig Daymon
I'm wondering if it is possible to thin water-based finishes (using distilled water) to use as a wipe on finish. I'm thinking it would be better than oil based for places like the inside of boxes. Anyone ever tried it? Any suggestions or things to consider?
Thanks,
Craig
Re: Thinning water-based to wipe on?
John Veerkamp
My experience with WB is that it is thin enough from the can to wipe on. You do need to work quickly and DO NOT overwork.
It works great
I've been using Velvit Aqua-Shield as a wipe-on finish for quite a while now. It is quite thin right from the bottle and dries very fast. I find it makes a good sealer coat for woods that I don't want to darken too much with oil finishes. You can sand it back and get a nice build in fairly short order. I imagine this would work with most of the WB products out there. Most don't recommend thinning very much, if at all. Check the directions on the can.
Donna Parrillo
Donna Parrillo
Minwax makes a Water-based wipe on poly.
It's a good product. I'm going to buy some more tonight. I tend to use it during the winter because it's hard for me to spray lacquer when It's cold outside and I have open flames in the shop. I may be dumb but I'm not stupid. :)
I don't thin General Finishes High......
JamieDonaldson
...Performance H2O based finish to wipe on, and don't make the mistake of wiping it too much as it skims over very quickly. I also just bought a can of the GF Woodturners Finish which is an H2O finish, but haven't had a chance to use it yet.
