storing blanks and such...
darrin hill
I've accumulated a large pile of logs and today started to try to trim out bowl blanks..
I've done what the locals told me to do and painted a coat of paraffin on the ends when they were cut... i cut some blanks and put more paraffin on the new cuts...
so i was gonna rough them out and let them sit.. in shavings, bags, loose, .. but as i rough them out, should i paint parafin on them again on the endgrain or bowl edges to keep from cracking? i know not to cover them completely, or they wouldnt dry out... just wondering if a little in the right areas would help..
d
Re: storing blanks and such...
Ian Jeffcock
After roughing I use and recommend coating the entire bowl with Anchorseal. Put it in a grocery (brown paper) bag with some of its shavings, and store in a cool place for a few months. I then take them out and let them dry on a shelf for a few more. I think using paraffin wax would prevent drying too much. Some other factors are where you are storing and what your climate is like. My shop is cool enough that I have to watch for mold on certain kinds of wood. In these cases after coating with Anchorseal I leave out for a few days to dry some before bagging. It will take a bit of experimenting to find what works for you, and how different kinds of wood act, but hang in there...its not rocket science.
Hope this helps, it works for me.
Darrin They will dry if covered completely it just takes a lot longer. I'm not an expert on this because I have had to experiment with lots of species and different sizes and shapes. This means it's hard to really nail down my failures. Some of the things I do may not be necessary but to me at least seem to have reduced my failures to a very small amount.
For solid bowl blanks I seal them completely with paraffin if they will fit in my electric skillet. I try to at least seal the ends and will sometimes paint wax onto areas with knots. I've started using Anchorseal for some of the areas instead of just wax. It seems like if I wax the ends the other areas aren't as important but it costs little in materials and time to just go ahead and seal them.
For roughed out bowls my failures have most often started at the lips or the tenon. I try to not leave sharp edges because I think these dry out too fast and that's where the checks start. I have started sealing the entire lip and tenon area with Anchorseal and will paint it on any end grain areas. Again this might be overkill but my time is short, Anchorseal doesn't cost that much per application, and lost bowl blanks are really frustrating.
I gave up on the shavings thing along time ago. It didn't seem to stop any checking and just caused a lot of mold on the pieces. I still use paper sacks sometimes for fruit woods or wood that is special to me and I don't want to lose. I'll put it in the paper sack for the first month or so. when I turn green bowls thin and to completion I'll use the paper sack for the first couple of days to slow down the drying. Then I can usually pull them out and put them on the shelf to finish drying which takes about 5 days or so.
Since I can't turn as often as I like some of the larger blanks that I only sealed the ends will start to check, maybe 9 months to year down the road. When I see this I cut them at the check into smaller blanks. I leave them the full length but cut them into 5x5,4x4, 3x3, all the way down to 1x1. I seal the ends and put them up. These will be box blanks and smaller projects.
Recently I have started cutting some of the wood into future mirror blanks so I cut it 6"x 1" and as long as I can. I'll then cut handle stock that is 1 1/2 to 1 3/4" and as long as I can. I try to keep these together. They seem to dry in about a year or less.
I know it seems like a lot of work but my failure rate has gone down to the point that I now have a wood storage problem instead of lots of nice firewood. It's really not that much trouble once you get in the habit.
One more thing that has saved a lot of wood. When I first get it I rarely have time to cut it up right then. I set the logs on end and then cover the other end with plastic garbage bags. This works amazingly well at preserving them for many months until I can get around to cutting them down. I think if you had a way to keep the sun off of them such as a building or large tarp it might be just about as effective if not more so.
Mike Stafford
Mike Stafford
John points out a general rule of air drying when he states that the green wood he is cutting for mirror blanks dries in about a year. In the thicknesses he is cutting that should be about right.
I have heard that green wood air dries at the rate of one year per inch of thickness plus one year. I cannot say that I have verified that to be true but I have 3 inch box stock in the square that is 3 years old and it appears to be pretty dry. I still rough turn stock such as this and let it dry more before finish turning.
Denis Putland
Denis Putland
Darrin
Sounds like you intend to turn the wood when it is green and then dry the rough outs.
If so then there is absolutely no reason to pre cut the logs into blanks.
Do the cutting to blank size as you have the time to turn, that saves you all the trouble of sealing the blanks.
Just seal or cover the log ends.
Leaving in log form for as long as you can also gives you more lee way as what you eventually turn from the said wood.
If you cut up a pile of blanks and then decide you want bigger ones I have found it extremely difficult to cut them into bigger shapes!!!!
Denis
Stuart Johnson
About the only two methods not mentioned is Wally's coating the roughed out bowl with Johnson Paste Wax and alcohol soaking. Out of curiosity what wood did you get? Some like Mesquite won't have much of a cracking problem, Cedar Elm isn't bad and Hackberry is better if left to spalt.
Bernie Weishapl
I agree with what has been said. I will leave the logs with the ends sealed as long as I can out of the sun and covered with a tarp. When roughing a bowl I agree with John to round over the lip edges of the bowl. I coat the whole bowl with anchorseal and let that dry. I don't use the shavings or the bag anymore. I store them in a room that stays about 65 to 70 degrees year round with not much air movement. I stack them on the floor not more than 3 ft high. Depending on the wood it is ready to return in about 9 months to a year. It is extra work but I started roughing a bunch of bowls every so often. Now I have a stash that is ready to return to the lathe to finish. As I finish a few I also do a fresh batch of roughing green wood. That keeps a supply going.
Brad Vietje
Brad Vietje
Hey Darrin,
Stuart asked some good questions, so I'll follow up with a few more:
1. What kind of wood?
2. Where do you live?
3. What storage is available?
4. Heated, or cold (back to #2...)
5. If heated, how?
What you do depends more on these variables than anything else. What I do in Vermont, or what Wally does in Arizona might not be right for you.
I seem to live in a pretty forgiving climate. I use a paper bag or box for most bowl rough-outs, and only use Anchorseal for high-value wood that's prone to cracking. I never use both. Wet shavings, as others have reported, are good fr spalting the wood or growing mushrooms, but don't seem to be helpful for seasoning bowls. For the past 4 - 5 years I have only rarely used Anchorseal -- Wally uses paste wax in Arizona, which is a lot drier than here, so if it works for him, it's good for me! I use Johnson's Paste Wax and smear or melt it on as the bowl is spinning.
I almost never lose a roughed out bowl to cracks, but have lost a few to excessive mold or spalting from the moisture in the bag or box, or the rainy weather.
I store rough turned bowls in an unheated barn, usually down near the dirt or concrete floor. If you dry things in a heated space, it won't take as long, but you'll probably have more cracks, especially with forced hot air heat, which is really bad for drying bowls.
Safe sinning,
Brad Vietje
Newbury, VT
I love sinning safely!
Jorge
Thanks for the chuckle Brad...
I don't use paper nor shavings and just let them be, like Brad store my rough turned blanks in an unheated building with little air movement.
Yes occasionally one cracks, but most just dry nicely and they are dried ready to final turning somewhere between a month and six, depending on the wood.
Wood to be made into blanks stored outdoors, on the shade, facing north. To this chunks, I do apply Anchorseal if I cannot jump into turning them right away.
Re: I love sinning safely!
darrin hill
so how do you know when it's ready to turn? weight? or do u just say 3 months is good?
was wondering about having safe sinning... not sure i want to go there... but ..
ok.. screaming twins are calling... was gonna make a joke, but insert your own safe sinning one here..
d
Jorge
Darrin,
I was just making fun of Brad's misspelling.
I do weight the roughed blanks and write it down on a piece of tape on the blank, along with the date. occasionally I weight them again and when they weight the same as last time, I call it done.
darrin hill
i caught the misspelling earlier... just wanted to see if anyone else had..
Darrin I use to weight them but never had a really good way to write it down so I could read it 3 months down the line. Now I have so many laying around that I just try to stack them so the newest ones are nearest the wall on one end. That way I just grab ones that are away from the wall and they are at least 6 months old or more and dry.
when I did weigh them I found I could turn them in 3 months with minimal warping and they were dry in 4 to 6 months no matter what size. That's here in Tennessee in a no air conditioned building.
I have a new really inexpensive moisture meter so next time I get some fresh wood I'm going to do another weighing test and measure it as well. Then I'll check it and weight it frequently until dry. That should give me some idea if the moisture meter is any good and at the same time tell me how long it takes that species to dry in my new location.
Dale Bonertz
Lot's of good advice. As said most wood will be dry in 6 to 12 months if you use the 10% guideline (IE: 15" bowl = 1.5" wall thickness). Some even sooner especially the smaller bowls that have a 3/4" wall. I tell any new turner to be less concerned about finish turning anything. Be more concerned with finding free wood and just rough turn bowl blanks. Great tool control practice, practice the different cuts and shear scraping, who cares what the surface looks like because you will be returning (finish turning) it and in six months or so you will have more bowls blanks to finish turn than you will probably ever get done. Of course most want to finish turn something anyway. :) The only extra advice I want to add is label the blanks. I will write on the tenon or block with a sharpie the date like (11-11) and the species like (M for maple). You would be hard pressed to find wood in my shop that does not have a date I started drying it (month/year) and the species. If you do this from the beginning you will never have I forgot or dunno wood. Just remember this is an older persons sport and our brain hard drives are getting full and we forget things. :D
Brad Vietje
HA!  Had a good belly laugh over that one!
Brad Vietje
Good thing I'm not running for president!
Brad Vietje
...so, did Herman Cain touch any of those women ???
NEIN! NEIN! NEIN!
Can't make up stuff this funny.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Good thing I'm not running for president!
Wally Dickerman
Hey Brad, you're a real comedian...Took me a minute or so to get the nein nein nein Shtick.
sortta related
Ian Jeffcock
A little of topic, but I have a question about the 10 percent rule on wall thickness.
When you get into the 26" dia range, which I have been doing lately, that makes for a hefty rough out. Do you guys modify thickness when you get into that range. Also a similar question as to ideal wall thickness on finished bowls of that diameter. I have been going with what looks right and seems to be proportionate, but it feels strange after working on "normal" size stuff.
Re: sortta related
Dale Bonertz
Ian,
I have only roughed up to 22 inches. I left that at 1 7/8" thick. I don't think you need a wall thickness any thicker than 2 inches max. But then again I have only gone as big as 22 inches.
Re: sortta related
I would say it depends on the wood and how much it warps. I've only done a few that were right at 20" and left them about 1 1/2 and they were OK, could have maybe gone thinner. They were maple and Box Elder neither wood actually warps all that much when cut as a side grain bowl.
Wall thickness when finished was probably about 5/8" but like you I don't worry about it, I just do what looks right and feels right.
