Veritas - Innovation in Tools
Oneway Live Center screaming
Jorge
Today turning a vase the live center started to scream, it feels rough like the ball bearing is shot. It is less than 2 years old! I have a couple others, the one of the nova, 6 years old and works just fine and a Delta, noisy but not screams.
If you had his trouble, how did you fixed it?
Thanks
Jorge
Re: Oneway Live Center screaming
Jorge I haven't tried to repair one of those style live centers yet so can't help you there. I haven't heard of Oneway centers going bad but have heard of the Powermatic/Jet centers going bad. I'm with you. My Nova live center is at least 10 years old and maybe older and is still running strong. So far my Powermatic center is also and it's about 5 years old.
I'll try to look at my center this morning and see if I can figure out how to rebuild it.
Malcolm Ray
Hi Jorge.....Mine is 10 years old and still going strong....try giving Kevin at One Way a call.......I bet he will take care of it for you...Mac
Jorge
Thanks Mac, I will.
Jorge
Looks like is an easy job with the right tool...
Tank you John.
Re: Oneway Live Center screaming *LINK*
Very easy to get apart. All you need is a Park spanner wrench for removing bicycle pedal bearings. You could build on of these in a few minutes if you have a way to chuck up small steel rods in your lathe. Just stick one end of an 8" rod though the chuck. Use a file to shape the pins on the end. Then heat it and bend the ends 90 degrees and I would harden them a little while I've got the heat on. Then just bend the whole thing in the middle to make it springy.
This allows you to get it apart by unscrewing the outside. Then end piece comes off with snap ring pliers. Mine has 2 bearings with a metal spacer between. The piece held in by the snap ring has a slot so it might have to be unscrewed with a wide flat screwdriver.
I don't know if the bearings would have to be pressed off or not. I didn't try that.
http://www.parktool.com/product/adjustable-spanner-spa-6
Jorge
I'll try to make one.
Thanks John!
