My quill is stuck and will not rotate with the hand wheel. It is less than a year old and I do not use it much as I turn mostly bowls. Have not used to drill anything and only turned a couple of spindles with it. I do use the tail stock when turning large, 16 to 19 inch, wet blanks.
According to the tech at WM I must have turned the handle too hard and done something to the treads inside. He asked if I had had the quill heat treated? I said no and if it needed to be heat treated why didn't they do that when it was made. No answer other than" that is what I am telling folks when they call in with the problem."
Has anyone had this problem and what was the solution? Thanks.
I have never seen a 3520 in person so I can only guess. On my DVR there is a keeper plate close to the handwheel. It is secured via a screw which is accessed through a small hole in the handwheel itself (the wheel is solid, no spokes). Just a guess but if the 3520 has a similar set up, it may need to be greased.
skip When you back the handwheel all the way back so the quill bottoms out it will sometimes stick and take a pretty good whack to get it moving again. I'm at work and can't remember which direction backs the quill. Heck at my age I'm not sure I can remember after I leave the shop. Seems like CW retracts the quill but don't quote me on that. If you can then tap the handle close to the wheel pretty hard with something. If you hit it the wrong direction you will lock it even more. I will be home about 7 tonight and can check unless someone else gets to you first.
If it's stuck in some other position I'm not sure I can help with a little dissassembly of mine. I'll check back when I finish the next shoot and see how your doing.
I can't imagine why in the world anyone would heat treat the quill other than the factory. I suppose if it was really hard and the threads on the screw were soft you could strip some threads with too much force. In that case the wheel would spin but the quill would not retract or extend.
I don't have a 3520 or ever had an opportunity to use one, so I can't be sure of what your problem might be. However, I've owned a number of different lathes and have had the situation of the quill not moving back and forth when I turned the handwheel. In each case, the locking screw which is supposed to lock the spindle when you have it tightened has a reduced size end that fit into a slot on the tailstock spindle shaft. If that screw became backed out enough to get out of the slot the spindle would not move in or out when the handwheel was turned.
Does the 3520 have such a locking screw and a machined slot for the screw to ride in? If so that could be your problem.
Yes, the 3520 has such a screw and channel but that does not seem to be the problem. When the quill is in the back position it will not turn. I am going to reassemble it and try what John suggested. I suspect the quill got turned back too far the last time I used it. I was afraid to take a block and hammer to it but it can't hurt at this point, I guess.
Skip, Here ye go: First, loosen the quill locking lever up on top.
Remove the small screw with a jam nut located on the right side, at the headstock end. The screw takes a 5/64 Allen or maybe 2 mm.
Remove the hand wheel by loosening TWO set Allen set screws (4 mm).
Take a file and clean off any burrs created by the set screws on the shaft where the handwheel was. This is important.
Place a piece of wood against the end of the shaft where the handwheel was. Hit this piece of wood with a hammer. See what happens. The shaft and ram should move forward. If it didn't, hit it one more time, pretty hard. Did it move?
OK. If it didn't move, get a good penetrating oil (Liquid Wrench) and apply liberally to the quill at the other end. Put a little on the shaft at the handwheel end. Let it sit for several hours. It would be good to remove the tailstock from the lathe and orient it vertically so the penetrating oil will tend to run down around the quill. (Do not use WD-40)
Then hit it again. Hopefully, it will now move. If it does, then try tapping it first one way and then the other to loosen it up good before you try driving it all the way out the front. Apply lots of penetrating oil.
When you get it out, clean it up good. Also, clean up the bore where the quill runs. Apply a good machine oil, and then put it back together.
My quill has gotten stuck when retracted too far. Give the handle a good yank counter clockwise and it should free up. If not you might try a rubber mallet.
Skip If the quill is pulled all the way into the tailstock and locked up you need to turn the handle clockwise to release it. I can usually do it with a hard blow from my hand. I've never had to use a mallet but I have had to hit it pretty hard.
If the handle is moving freely and the quill isn't extending or retracting the screw or pin that fits in a slot in the quill is either loose or has fallen out. the early 3520's had a tapered pin that fits in a hole in the tailstock and is driven in. They sometimes fall out. On the 3520B they changed this to a set screw that goes in from the back side of the tailstock and is a much better design.
Your question is timely. I am having a similar problem, though mine is not stuck. It does bind quite a bit. I got similar instructions about the hardening from the WMH tech. Mine gets tight after the quill is in about 3" or so, even without the leadscrew installed, which tells me it is not the threads, even though I do a lot of drilling. It seems like there must be a burr on the inside of the tailstock, but I have honed it out with sandpaper on a dowel, and cleaned all surfaces and it still binds, so I wonder if the quill is bent slightly? I have a new quill and leadscrew on order. Guess I'll have to wait until they arrive to know for sure.
Skip, You should have had those blanks done by now, heck you've had a couple weeks If your in a pinch, you can borrow mine. It seems to me that mine did the same thing once and I ended up just giving it a wack to get it going again ( kind of like a kid)
Thanks for all for your help. As usual, when I come to this forum for help or knowledge you all share wonderfully.
John, it was indeed that the quill had been backed up too far. Until the post from you,Fred, Doc and others, I was afraid to whack it too much. Didn't really understand what was going on and if I get too physical usually it ends up making things worse and costing money.
I filed off any burrs and really oiled it up before I put it back in. Still binds a little but it functions so I can keep going.
Apparently, somewhere in the process I lost the ability of the center to pop out when the quill is backed up to a certain point. I can live with this though.
I am trying to spread out the fun for awhile. Have gotten some pretty nice pieces out and several are in the kiln, as we speak. I will not be at the meeting this month. I hope to being back some myrtle or big leaf maple from our trip. Do you want me to pick up some for you too. If so, let me know how much of your wallet you want me to leave over there.
More than likely when you jambed the quill back into the houseing you probably upset the lead screw threads back at the handwheel end. This would prevent you from drawing the quill all the way back in like you did in the past to kick out the live center.
You might be able to run a die over the threads and clean then up. You'll lose some materail to the threads but should still work if they are not too damaged.
When you say you filed off any burs I assume you mean to the quill outside surface. May need to polish this some with emery cloth if you did not use a fine mill file carefully.
The quill internal threads should be check but the lead screw threads are usually softer material and will damage first.
Just thoughts for getting it back to normal functions.
