Finish Hot Box
Finish Hot Box
Finish Hot Box
dgelnett
I would like to build a temperature controlled querying box to ensure my finish is hard before wet sanding. Anyone knows of an inexpensive thermostat that can handle a 110v light bulb. I believe the thermostats for the house is low voltage.
Thanks
Re: Finish Hot Box
Re: Finish Hot Box
How about a baseboard heat t-Stat? Probably come set up for 240 volts, but you could just use one side. Not incredibly accurate, but should work and be cheap. I'm sure they are available at any of the borgs. $19 at Lowes. I think I ahve soem old ones in the shed that I salvaged out of houses I work on and pack ratted. If I ahve one I'll send it to you for the cost of shipping. Very old school and low tech.
Re: Finish Hot Box
Re: Finish Hot Box
tony wheeler
fan limit switch for a furance is adjustable from 90 dont remember the top side maybe 180 they are set for the temp that fan goes on and off
Re: Finish Hot Box
Re: Finish Hot Box
Dick Coers
Pretty sure those furnace switches are all low voltage too. You can get a furnace fan relay, and then use the heat exchanger thermostat. I would worry that you could crack the turning unless it is really dry. Some woods will heat crack from just too much sanding heat. Be careful.
Re: Finish Hot Box
Re: Finish Hot Box
Bernie Weishapl
I have to agree with Dick. I would be careful. I put a cherry bowl that I had finished and wanted the finish to cure good before I buffed it. I even put a low wattage bulb I think 40 watt and it cracked the cherry bowl. I had it regulated to between 85* and 95*. I didn't want to be late getting the bowl to my friend. I just let them cure on the shelf now.
Re: Finish Hot Box
Re: Finish Hot Box
Bernie Weishapl
I got fat fingered on my post which should have read, I put a cherry bowl I had finished in my kiln.
Re: Finish Hot Box
Re: Finish Hot Box
dgelnett
wow thanks, never thought about that, this may not be worth the effert and to many risk. thanks for you advice.
