Veritas - Innovation in Tools
Follow up on soaking Spalted wood???
My son mixed some lacquer with thinner and made it about 3 parts thinner to 1 part lacquer. Dropped int he pieces of spalted wood. The bubbles were amazing. The ends of the pieces foamed and frothed. Put champagne to shame. I was amazed at the amount of air that came out. These are small flat pieces about a 1/4" thick and either 3" x 6" or 6" x 6".
So, for the questions. Did we get get the ratio right? 3 thinner/1 lacquer or should it have been the other way around?
And how long to soak it? Until the bubble stop (a few minutes) or hours or over night?
Then how long to let it cure?
And would soaking it again do any good?
Re: Follow up on soaking Spalted wood???
John Veerkamp
When the bubbles stop you can remove the wood. Your ratio is about right. not critical. It will only take a day or so to be ready to use. Let us know how it works out.
I don't soak the piece although I guess that would work. I dilute my lacquer 50/50 with thinner and then blot or even squirt it on the punky areas. there isn't much need to soak the non punky areas because they cut clean anyway. sometimes it will absorb quite a bit. If it's really soft wood I put on several coats. If it's not that soft but just tears out easily I just put on once coat.
Yesterday I did some experimenting on a punky piece and tried different cuts and higher speeds and different tools. I got good results with higher speeds and a certain cut with the 40 degree bowl gouge but I need to do some more experimenting before I post the results.
