I needed to shoot these ornaments before I give them away tonight so I set them up in my living room. I used a seamless paper back ground but you can use just about anything that is smooth and a neutral color. I place them about 4 feet from my living room double windows. At this time of day it's not direct sunlight. I put a large piece of white cardboard on the left to bounce light back into the shadow side.
I put the camera on a tripod and used my 55-200 lens at about 100mm. I used Auto White balance which worked only because I had the gray background. I would normally use the shaded house white balance setting for this setup. The camera was set in manual mode and shot at 1/3sec at f11. I also used manual focus. I used the self timer to trip the camera because the tripod was on really soft carpet.
The two ornaments on the left are solid. The two on the right are hollow. Left to right, Oak, Cherry, Cherry, Maple with mahogony finial.
I like the cheap and easy setups, as long as the results are decent, which yours definitely are. I had two questions about your description of the process: 1) Why did you select f11 as the best aperture? and 2) What does the gray background have to do with automatic white balance?
I didn't need f11. This was basically a more or less flat subject and 5.6 or 8 would have been good although I might have had some of the subject slightly out. F 11 pretty much guaranteed that all of the ornament is in focus. The Maple and mahagony one was still moving when I shot the photo and the finial was mildly fuzzy due to this. I didn't pay close enough attention to this and only saw it when I enlarged the photo.
The gray back ground was close enough to 18% gray and filled the frame well enough that the camera exposed the scene correctly. 18% gray is roughly what camera meters think is normal. If the ornaments had filled more of the frame or if it was a big ebony vessel the gray back ground would not have had as large of an influence on the exposure. Also the change in background color would have also changed the exposure. Best to look at the image closely and then do what ever is necessary to get a correct exposure.
What I really want to know is where did you get that neat adjustable base, upright, and articulated arm, and how much such a device would cost. Looks like it would be really useful for setting-up all sorts of specialty shots (i.e. used with reflectors, black boards, snoots, etc.).
Thanks for your efforts in teaching us about both the turning and the photography - much appreciated!
