Sanding hood
robo hippy
Home made sanding hood so I don't have to wear a dust mask.
http://www.youtube.com/watch?v=lLHkEXVkAqw&feature=feedu
robo hippy
Sanding hood
robo hippy
robo hippy
Re: Sanding hood
Ralph Lindberg
Nice hood, BTW, I was over looking at your scraper video, saw this one (which wasn't there last night), it was listed as only having one view, so I guess I was viewer number two!
PS, on your scraper, is the main one 3/8 inch thick? That's what my un-calibrated eye is guessing
Re: Sanding hood
Ron McKinley
Great idea and well executed! ........Ron
Good idea Reed!
Jorge
As I work on a non heated space in the winter, using the regular face mask is not possible, condensation happens rather quickly and eventually ice build up.
So your solution is attractive to me, how big is your dust collector?
I did watch a couple other videos, they are all good!
Thanks for posting them
Jorge
Re: Sanding hood
robo hippy
Ralph,
Yes, it is a 3/8 inch thick by 1 3/8 inch wide Doug Thompson scraper. I do use a 1/4 inch one for the bevel rubbing shear cut on the inside. 1/4 inch scrapers just don't have the heft for a heavy roughing cut, no matter how close the tool rest is. Actually, a 1 inch wide scraper would work fine. I have no problem with stalling my Beauty with this. Not because of any short comings with the lathe, but because of putting that much steel into the wood at one time is a pretty bit bite.
Jorge, I have a 3 hp Oneida dust collector. I got it so I could run 2 machines at once. At most, there is maybe 4 sq. ft. of open space. I would expect a 1 hp dust collector would do just as well, especially if you are standing in front of it as all the intake air is funneled into the hood. You can buy sheet stock of that type of plastic and make one from scratch, and probably one that could be left in place. It would probably give you more shelf space as well.
Like some one at our last club meeting said, if you are blowing out presto logs, you have a dust problem. YUCK!!!!!!
I do have an old CPAP machine (snoring machine) which I had thought about hooking up as a positive pressure dust mask thing, but with the hood, never got around to it.
robo hippy
Any static build up?
steven antonucci
Looks like a plastic drum... just wondering if you've gotten zapped in the cold weather from a static discharge. My garage is dry, and I get hit all of the time when it starts getting cold. A plastic drum would probably kill me
S
As I debate finish sanding three nested bowls I turned this weekend...:)
Re: Sanding hood
robo hippy
I never noticed the static on the drum. I have had some on the acrylic end, which I hit with a dryer anti cling sheet, and that took care of most of it. Pretty wet here in the winter, 80 to 100% most of the time. I would think a ground wire might bleed it off.
robo hippy
Re: Sanding hood
Mike Peace
Do you regularly have to remove the hood when using the tailstock? How does the hose fasten to the back? Can you show a picture of the hose connection to the hood?
Thanks,
Re: Sanding hood
robo hippy
I may be able to find that shot eventually. You can see the vent, which is a floor type and the hose attaches through the back near the headstock. You can just see the hose through the acrylic. I did use sheet metal screws to attach it to the plastic, and used hot melt glue to seal it. Caulking would probably work as well. Original model was a round hose that attached on the back, pretty much the same set up, but the hose came out at 90 degrees.
robo hippy
Re: Sanding hood
Dave Peebles Lyons, Ohio
Hi Reed,
I was hoping you would show how well it works.
Maybe you can on the next one.
Dave
Me too....
I was hoping to see some dust fly....Away and into the chute. The video stopped rather abruptly, someone threw open the car door and said, Get out here!.
I think the adapter you used is called an "End Boot". Comes off the end of the duct in a straight line rather than at ninety degrees. There are many variations of duct fittings that can be useful. Its a good idea to go to a large duct supplier and check out their catalog.
Thanks for posting.
