Wiring
Don at Central Illinois
I need to run about 36' of wiring for 220v. What size wire do I need? I'm going to run the wire and let the electrian contect it all.
Wiring
Ask the electrician
steven antonucci
If I was an electrician and I was going to do the final hook up, I would want to know that everything after my work was good too, before I got blamed for the code problems.
Local code varies, so ask the guy doing the hook-up.
S
Re: Ask the electrician
I must be having a harder day at work than I thought. I'll call him tonight and ask. Doh.
Re: Wiring
And he'll ask you one question - what is at the end of the line?
If all you are carrying is 20 amps max - 12 gauge.
If you need a higher carrying capacity - 10 gauge.
Re: Wiring OT
bill Crommett
I have an electrical problem, too. How does one find a true electrician rather than just a wiring specialist ? I have an electrical leak from my lake pump for the irrigation system, and because electrical leaks in fresh water can be fatal to swimmers I have not run the lake pump for two months. I have done the wiring for the system myself twenty years ago and it was all according to code, but I need someone to tell me how to find the leak and how to fix it. The leak has just occurred in the past year, and all the electricians around here are wiring specialists , and I don't know how to find a true electrician that knows electricity beyond the wires.
All clues accepted.
Re: Wiring OT *LINK*
Guy Bratt
Hi Don
When you call your electrician you'll need to give him/her the name plate voltage and amperage rating of your appliance/machine. If it's an air conditioning system tell him that because the name plate has other info needed.
Hi Bill I've never heard of a wiring specialist. I wonder what a wiring specialist does? I'd call electrical contractors in the yellow book and ask them if they are licensed electricians. Their out there. You could look here for qualified contractor in your area. Look at the very top of their page for a locator link.
National Electrical Contractors Association
Re: Wiring OT
bill Crommett
Thanks, Guy. A wiring specialist is a fellow who knows how to run #12 wire from one box to another and not much more. In an area where construction was rampant until the bubble burst there were lots of them, including the fellow who painted my house.
Re: Wiring OT
Jerry
I am thrilled to be able to finally contribute something to WoodCentral.
Last summer I decided to upgrade the circuits in my garage so I could purchase a larger lathe that ran on 220. I also want to add a heater for the winter and have enough circuits to run my 120 power tools. A fellow wood turner's friend, Larry, who is a licensed electrician in Virginia (at 703-642-0043), came to my house, assessed my needs, and ran the following from my 200 amp circuit breaker panel (which is located at the other end of my house) into my garage: an SEU aluminum cable, which is about an inch thick, into a 100 amp sub-panel. From that sub panel, he ran the following dedicated lines: 4 more 20 amp - 120 lines, 2 - 20 amp 220 lines, and 3 - 30 amp 220 lines. Note that the 120 lines need to be GFI lines in my state. You will need to check to see that your existing panel can accept the additional circuit breakers to run the large cable to the sub-panel. As an alternative, I could have run a single 220 circuit to the garage, at less cost. However, I know I want (need) a larger lathe and a heater. I may also get a 220 bandsaw at some point. Everything was done to code. I may have run more dedicated circuits into the garage than I will ever need, but now I can plug each tool into a dedicated circuit, and not have to worry about blowing a circuit. Larry gave me permission to use his name and telephone number. If you live near Northern Virginia, perhaps he could help you with your electrical needs. I told my Capital Area Woodturners friends about Larry and he has wired other member's garages as well.
Re: Wiring OT
Don't imagine he wants to come to central Illinois and if he did, I couldn't afford it! I'm going to talk to the electrician this weekend. Thanks all.
