Adding REVERSE to a JET Mini VS - the NEXT Questio
charlie belden
Thanks to Bob Davis's pointer to the archives of the article on how to add REVERSE to a JET Mini VS, I'm "almost" done with the switch/wiring/switch box to THAT part of adding this feature to my lathe.
Now comes the NEXT question - How to keep the adapter ON the drive spindle AND the chuck on the adapter?
1. Lok-Tite the adapter to the drive spindle on the lathe and set screw a chuck to it?
(Would Lok-Tite be strong enough to hold?)
2. Drill and tap an adapter and set screw it to the drive and set screw the chuck to the adapter?
As is often the case, most solutions create new problems.
Any opinions or suggestions?
Re: Adding REVERSE to a JET Mini VS - the NEXT Questio
Charlie I just tighten the chuck or faceplate down good after I install it. I've never had a piece come loose on the mini lathe using reverse. I have had one come loose on the Powermatic but I think it was the mass of that piece that did it. I've also had one come loose in forward when the electronic break kicked in. I now turn the lathe speed own first and then hit the stop button.
Charlie, Like John, things coming off the lathe due to it being in reverse has been very rare for me. Let me say that I don't actually turn in reverse. Thought about it but never have. Might consider it inside a vessel, but have not done it.
What I do is give the faceplate or chuck a little "snap" on the last quarter turn and I find that works perfectly for things like sanding. Takes about the same little bump on the wrench to get them loose.
I did have one piece start to unscrew itself and realized it was because I never actually seated the chuck. It was not very exciting. It sat still, moved about half and inch to the left and plopped onto the ways.
It is a good idea to seat the adapter into the chuck thoroughly and perhaps use Loctite and a set screw, but There have been discussions here about people who used the set screw to the shaft, forgot about it and damaged the shaft when they got out the bigger wrench to get the "stubborn" chuck off the shaft.
Does your lathe have the soft start feature? Even better.
Don Evans
My opinion only:
I would NEVER use locktight on the spindle, first you have to make sure you use 242 type AND you need to let it dry before it is effective.
I would drill and tap the adapter with an allen head screw and here is important part of that, (plan ahead with size screw so you can get a solide BRASS rod that just fits into the hole without hanging on the threads inside. Cut a waffer off the end of the brass rod, 1/8" thick waffer, may as will do several while at it. You put the waffer down in the hole after the adapter is on the spindle tight, then screw the allen into hole hitting the waffer. The brass being softer will not harm the hardened spindle thread and will lock it.
There is nothing new about this, it has been done on lathes going back to early 1900's I know. You can also get allens with plastic ends on them that works also but you'll need to replace them after so many times being removed from lathe.
Teknatool uses a rubber waffer same purpose on some of their chucks (small red one) but not for this purpose. There is one located under the screw that holds the adapter in the chuck.
Don
You should still use the tailstock when reversing:
At the hardware store you can purchase rubber tips for wooden chair legs or used for walking canes. There is one of these that fits over the threaded end of the oneway live center and I use it so I don't hit the sharp point with my elbow. With this tip covered I bring the tailstock up, put not touching, the end of the turning IF it is in a chuck.
This way, if chuck does come loose, it cannot screw completely off the spindle, most of the time there is only about 1/4" gap between rubber tip and wood.
Since using random (rotating) sanding most of the time, I don't really find much use in reversing my lathe.
Don
Here's the link to the thread on adding REVERSE to a JET Mini VS.
If you're good at mentally converting a wiring diagram to Real World and visa versa - AND - you're pretty good at thinking things through and solving problems - the info provided in the thread is all you'll need to know in order to make the modification. Note that this method uses an EXTERNALLY mounted Double Pole, Double Throw toggle switch. THAT complicates the modification a bit based on my experience - so far.
I THINK I have a simpler solution that requires no EXTERNAL switch and switch box- replace the stock On/Off switch with a Double Pole, Double Throw, Center OFF toggle switch. I haven't done this modifiction yet so if there's an electronic guru out there going through this thread = PLEASE let me know if I'm about to do something REALLY stupid - or dangerous.
Let's start with what the inside of the stock Control Box looks like and diagram what connects to what. 110V AC comes in from the power cord, one leg going to the stock toggle switch which connects in series to the breaker which connects in series to the speed control potentiometer which then goes to the Printer Circuit Board. The OTHER leg of the 110V AC power cord goes directly to the PC board. The DC motor's power cord comes off the PC board.
Now let's look at the Double Pole, Double Throw, Center Off toggle switch that will replace the stock Single Pole, Single Throw toggle switch. By connecting the upper left and lower right terminals and the upper right and lower left terminals and then connecting the lower terminals to the PC board's terminals that the DC motor HAD been connected to, we can flip the polarity of the current going to the DC motor. By connecting the DC motor's power cord lead the the two middle terminals of the DPDTCO switch we can now have the lathe spindle turn "forward" or "reverse" or turn the motor OFF.
Here's a diagram showing the modified set up. THIS is the diagram that needs someone who knows electronics to check out and verify that it will work - without any smoke, sparks or smell of frying electronics.
charlie belden
There's more to things than meets the eye.
Being able to have a turning spin "backwards" when needed is nice to have for several reasons. It makes hollowing a bit easier on the back because you don't have to lean over the lathe. It also lets you sand while the piece is turning "the other way" which can produce better sanding results.
BUT - and there always seems to be a "But . . ." - it also means that anything screwed to the drive spindle CAN unscrew itself when the spindle direction is reversed.
SO - loktite the adapter and/or set screw it to the drive spindle.
BUT - if you set screw it to the drive spindle the set screws will "dimple" the drive spindle, making getting the adapter off later.
SO - make a brass wafer to go between the set screw and the lathe drive spindle.
BUT - that little brass wafer will surely get lost when the adapter is taken off.
SO - make a bunch of little brass wafers so used ones that get lost can be replaced.
BUT - now you have to have a place for the spare wafers - and remember where that place is when you need another one.
Do i really NEED reverse? It's a JET Mini. I can easily just walk around the back and turn from there
IF - the Moffet lamps AND the dust collector shroud weren't behind the lathe - which they are.
BUT - I COULD ceiling mount the lights and dust collector set up . . .
Maybe SOME seemingly good ideas - shouldn't be carried out - unless well thought through ; (
Just wanted to add that a perfect use of a golf ball, with a hole drilled to fit the end of a live center, is a perfect way to hold a piece on a lathe. Use it every day, it seems, and it is a big helper. Phil
I have to seriously disagree with the idea you don't have to secure the chuck to the head-stock, when turning in reverse.
If it can screw on, it can screw off.
Trust me I know.
I use NOVA chucks, most of the inserts have a set screw so you can "lock" the chuck to the spindle so this doesn't happen.
I was getting ready to reverse hollow, the chuck I had it one, I noticed didn't have the set-screw. I thought, what the ... I will just make certain it's tight.
A few minutes of aggressive hollowing later, I realized the object was about to fall off the lathe. Fortunately it did not.
Now, both of my inserts, that don't have a set screw are marked, with bright RED faces, so I never try to reverse turn with them.
Lock the chuck to the lathe, never try reverse turning without doing that, you don't want to launch both the object and the chuck. Trust me
