Stabilizing spalted wood
This is actually a flatwork question. >(
My son and I have several spalted maple boards and want to resaw them into panels for some sort of cabinets. So what is the best way to stabilize them? Soak them in thinned lacquer. Minwax Wood Hardener? We are thinking of quarter inch thick panels in frames or doors.
Re: Stabilizing spalted wood
John Veerkamp
Unless the wood is soft & punky, all you need to do is dry them . The spalting fungus can't live in dry wood. If soft, try lacquer as suggested.
Steven Antonucci
Resaw to 1/8" veneer and make plywood
Spalted...
Scott Walton
If the wood isn't to punky, I have had great success with diluted Deft. Soak the wood for several hours until it is saturated and then lay out to dry. Deft really smells but is alot less expensive than Minwax's Wood Hardner!!! A 1:3 dilution is a great starting point and I have used that for 4" and 6" bowl blanks with great success.
Ken Vaughan
Stabilizing spalted wood - Cactus Juice
Ken Vaughan
The Pen Turners are using this product to firm up soft and punky wood.
http://www.turntex.com/index.php?page=shop.product_details&product_id=2132&flypage=flypage.tpl&pop=0&option=com_virtuemart&Itemid=18
Normal process is to use vacuum to assist penetration into the wood; followed by a heat treat to set the resin.
If the wood is punky or has soft spots, this will give you an end result more stable for further working.
Ditto what John said.  I've done it.
Thanks for the help.
