Lacewood (DRY) and end grain tear out
Craig Daymon
I'm attempting a shallow lidded bowl out of (Australian) lacewood. The wood is very dry, prone to splinter and the end grain is tearing out. Is there an approach to turning this to minimize tear out? Mineral oil? Would that effect finishing? (Minwax Tung Oil Finish.) The lid won't be lacewood.
Thanks,
Craig
Re: Lacewood (DRY) and end grain tear out
First thing I always try is coating it with Johnson's paste wax. If that doesn't work and I try soaking it with thinned lacquer.
Use a tool with sharper cutting angle and narrower tip. I find sometimes a narrower cutting tip works. I have a 1/2" spindle gouge and when it doesn't cut clean enough I use my 3/8" detail gouge. The detail gouge has a much pointier tip and I find it will sometimes clean up a cut that the 1/2" won't. Both of these tools are sharpened at 35 degrees and will usually cut cleaner than my bowl gouge which is sharpened about 50 degrees or my Stewart Batty gouge that is sharpened at 40 degrees.
Don Evans
I don't think Mineral oil will help you problem, what you are looking for is something that fills in between the fibers and most importantly gets hard. To cut them, they gotta be hard and tool will cut them, it not, the tool will just push them over.
Why not use the finish as tung oil will harden?
I've had success with the wax John told you about also, but you gotta give it time to harden. I put it on with a pushing and twisting motion to get as much down deep as I can in between the fibers.
Every type and different piece of wood within each type seems to be different when it comes to this and what will work best on that individual.
Don
