Stupid question time, transferring measurements
Randy Johnson
In various “how to” articles in different turning magazines I have seen pictures of measurements transferred from one piece to another by using dividers. An example would be fitting an inlay in a lid or fitting a lid to a box.
HOW do you determine where the point of the dividers should contact the wood? My current method is a ruler and a compass while the piece isn’t turning. The divider method seems like it should be more accurate, but for the life of me I don’t see how to scribe a line with dividers when there is no physical contact with the center such as you have with a compass.
Re: Stupid question time, transferring measurements
Steven Antonucci
For fitting things, I never transfer measurements
steven antonucci
I simply make a couple of small passes and test fit the two items together.
I could never figure out how to use dividers accurately either (with that level of precision at least...)
Steve
David Walser
Randy,
Using dividers is a skill that's learned through practice. What you do is rest the left leg of your dividers on your tool rest and line up the two legs with the spinning work piece until it appears that same amount of the work extends beyond both legs. Then, lightly touch the left leg to the work such that it barely scratches the spinning surface. Move the left leg left or right along the tool rest until the right leg of the dividers is exactly over the scratch-line being made by the left leg. Push the left leg of the dividers in a little more to make the scratch-line more visible and you're done.
The only caution is never, ever, allow the right leg of the dividers to touch the spinning work. The upward rotation of the spinning work (on the right hand side of center) will throw the divider up and out of your hand. Playing "find the dividers" not nearly as fun as it sounds.
With practice, you'll find the process very quick and accurate.
Re: For fitting things, I never transfer measureme
David Walser
I think that's the preferred method, but sometimes it's not possible. If you wanted to inlay something inside a shallow recess, a box lid for example, you might not be able to trial fit the pieces without parting them off. Turning something to fit a pre-made hole is a valuable skill. Sometimes the skill makes things easier (fewer trial fits) and sometimes its essential.
robo hippy
I use the dividers/compass to get close, then fine fit by trying the piece in place. Widen a bit, test fit again, till the fit is perfect. some times a tiny taper in the plug helps rather than a square side, so it wedges in tight.
robo hippy
I use that method but sneak up on the line. First it's extremely important to have the handle of the dividers higher than the point and the point should be at or higher than the center of the work. As mentioned never touch the right side of the dividers to the turning.
I kind of eyeball it and then touch the divider point on the inside of the the area I think is perfect. Then I stop the lathe and check. Then you can easily see how far to move it for the next line. Stop and check again. Usually by the 3rd pass it's pretty darn close. Then Ideally you need to sneak up on the cut as well and then test fit the piece.
I prefer to use dial calipers. I can measure the outside or inside diameter of something. If I measure the outside and want to transfer the measurement to the inside I use the short points designed for inside measurements to scribe my wood. You also have a choice of dividing the measurement in half and then putting one of the points in the center of the turning and scribing the outside mark. This is quite accurate. Then sneak up on the cut and actually measure the diameter with inside points. I still prefer a test fit whenever possible.
One thing I've never been able to do accurately is use those spring type inside and outside calipers. You set the inside calipers for a press fit and then adjust the outside calipers until they just kiss the inside calipers and use this for your measurement. It never worked as well as the Dial Calipers do.
