Rolled-in Platter
Ronnyeelen
This platter is Claro Walnut. Size is 48cm x 6cm (19” x 2.5”, approximately).
It has a rolled-in rim. I decided to that term instead of the previous ‘round rimmed ‘ I used on 2 of my previous bowls. The second picture shows a more detailed view of the edge. The other ones were rolled-in as well. But maybe that was not so clear to everyone. Someone said why don’t you use an undercut, to give some more effect. Hmm, I thought, how could I cut more under than it already is
So it was time to try to show it in a more obvious way. And I had to try hard, because it was no real fun to get it right. A hole in the wall tends to make the gouge bounce a lot. And the bigger the hole, the harder the bounce.
Next to the sap wood still visible, was a layer of decayed sapwood, an inch or so thick. It disintegrated into dust immediately when cut. So after the turning I decided to take it off completely.
Of course all comments and critiques are welcome.
Thanks for looking
Ronny
