how to put a radius on a skew
Dennis Taylor
I have a standard skew, straight across, what is the way to put a radius on the edge? Dennis
Dennis Taylor
Free hand
Jorge Casta�eda
Denis, I prefer the straight skew to the radius one, when I tried it, I did free hand shaping and sharpening.
Re: how to put a radius on a skew
Dennis in Southern Oregon
Assuming that you have the Oneway Wolverine System or equivalent, install the platform and adjust its angle so that the skew's angle matches the grinding wheel. Lightly grind one side while rocking the handle of the skew to the left and right to produce the arc that you want. (It should be very subtle). Turn the skew over and repeat on the other side.
Dennis
I agree with both of the methods above but I also don't see any advantage to a radiused edge. If your a serious skew user there might be some advantages if depending on your style of turning. If you think it will make it easier to use the skew it won't. Practice is what makes it easier no matter the shape of the edge.
Bob Lalonde
Hi Dennis. I did mine with files with decreasing grits (if that's the right word). It was easy to contol assuring accuracy and a gentle curve. Worked very well.
Having said that, I still prefer the straight factory edge.
Regards, Bob.
Mike Mills
I tried it on my 1/2" but went back to straight. I could see no better control and it was much harder to hone.
That said, here is a link to forming the edge by Alan Lacer. It should answer all questions.
http://www.youtube.com/watch?v=dmCxDToHm6Y
