Anyone repurpose planer blades?
Thad Parker
I've got a stash of 12" planer blades I'm considering using for various shaped scrapers.
I realize that a planer blade "scraper" would not have much range beyond the tool rest with it being so thin. Are there any reasons this should not be done, or any better uses for these?
Re: Anyone repurpose planer blades?
Steven Antonucci
Make a round stock handle
steven antonucci
and just mount short sections of the planer blade with a screw. No worries about breaking and no limitations. The only thing that needs to be good steel on a scraper is the edge. How it gets extended isn't a big deal.
Steve
Harry Robinette
harry robinette
I grind them into tear drops for my boring bar. Also grind them for scrapers that I make from 1/2" or 5/8"
round stock. Grind a flat and drill a hole when you go to make the blade from the planer blade grind it so a hole or slot is in the middle of it one thats already there from the original blade. HSS is really HARD to drill so use an existing hole.
just my $.02
If they are hardened hss it's almost impossible to drill. I use a cut off wheel in my angle grinder to shape small pieces like Steve mentioned. Then I simply cut a slot for my screws rather than trying to drill a hole. It makes it quicker to remove the cutter for sharpening and since you don't have to remove the screw you don't lose it.
Thad Parker
This difficulty is what I have found. Thank you for the solutions.
Stuart Johnson
You can also use an angle grinder and cut a slot for the screw rather than drilling a hole.
Skip Beardsley
We have several mills here in Montana and our club has access to some of the discarded planer blades. We also have a company here that cuts all sorts of things with high pressure water. I have several pieces of this material which I have made into various scrapers and skews of different sizes. Used a grinder on the end away from the sharpened edge to cut a tenon in the steel and make a handle into which the tenon is inserted. Make great tools and since they are relatively cheap I am more adventuresome about trying new grinds. I should think blades from home workshop planers should work as well.
Skip
You will think I'm crazy until you try this.
Keith Newton
I cut them in half, dull the edges, then sharpen both ends with a thumbnail, or whatever is needed for the moment.
I sharpen to about the same angle as I would a chisel, and allow the grinder to get the edge just red, to anneal it so I can roll a bur. The edge will crack out little bites if you don't anneal it.
To use it, I move the toolrest away, and freehand it. With just enough sticking over my gloved index finger, that my finger drags the surface, and a very light touch, I can traverse, or linger on a ridge, tilt for skewing, left or right.
I'm touching the work well below the center, so the hand is in a comfortable position, and the axis of the blade is slightly wider than, 90, but the bur is at a good cutting angle.
I can get a good enough cut, that i start sanding at 220.
Mike Stafford
They make fine parting tools.
Scrapers, Yes!!
Jorge Casta�eda
They make really good scrapers, and as they are thick they shatter rarely, I have an old 12" x 3/16" that is reserved to scrape table tops, as now and then I still make furniture.
With a burnisher you can put a burr on them, flatten it, put the burr again and this will harden it and keep it sharp quite a bit longer.
You can make any tools you can think off.
