200+ woodworking book reviews
At what point . . .
At what point . . .
At what point . . .
charlie belden
is a piece that's had voids and cracks filled wirh epoxy and sawdust or coffee grounds become an epoxy and sawdust or coffee grounds piece filled with wood?
Am having another go at a madrone arial burl piece. The chunk of wood I started with is laced with voids and cracks and inclusions running in every direction.. To keep it from exploding while roufh turning the profile I initially resorted to CA glue. But it was like pouring water into a small crack - that seemed to open into The Carlsbad Caverns!
Sixteen dollars worth of CA glue later I decided to switch to epoxy and black walnut sawdust. Made the foolish mistake it starting with FIVE MINUTE epoxy. Barley got the sawdust mixed in before it set off. So I got some 30 MINUTE epoxy, figuring that would give me plenty of time to mix and get into the deepest cracks. Seemed to work fine for the larger cracks. But for the smaller cracks under 1/8" I couldn't push it very far into the cracks.
Every time I returned the now epoxied piece, new cracks and voids would appear and in the areas with the narrower cracks, I'd turn right through the previously applied epoxy, exposing the crack again. To complicate things, some of the cracks ran tangent to the turned surface, "flaking off" as I turned.
So I'm thinking "Maybe if I did some hollowing - say to quarter inch walls - at least I could SEE which way cracks ran and MAYBE fill them."
But then my self preservation instinct thinks "This thing''s gonna disintegrate while I'm trying to hoillow it out some!".
So how do YOU deal with this type of situation?
Do you do the profile, filling voids as best you can THEN hollow?
Do you rough the profile and fill the wide cracks, start hollowing and Fill As You Go?
HELP!
Re: At what point . . .
robo hippy
Well, when it is that bad, it makes good fire wood, or leave the voids and turn it that way. I do know what you have with the dry madrone burl.
robo hippy
mjonesrdg
Charlie, I would take a chunk and sink it in a bucket of water for a week or so. You don't have much to lose for trying. West systems has a new wet surface epoxy that might make you a bit more comfortable than CA. in the event that by some miracle, the wood becomes more workable when re-hydrated.
Jim Evans
Jim Evans
Charlie, You might try the vacuum and white glue method used by Max Krimmel to seal Alabaster.
"...The vacuum chamber (made from 12" PVC pipe and particle board), and the lid for the chamber (also made of particle board). The faceplate on the lid allows it to double as a vacuum chuck.
The roughed out stone is put in the chamber and submersed in a thin (1/3 - glue/water) solution of Weldbond® glue. The lid goes on and the air is pulled from the chamber with the vacuum. I run the vacuum for about 3 minutes to evacuate as much of the air in the cracks of the stone as possible. When the vacuum is released, air pressure forces the glue mixture further into the cracks. I wipe the excess glue off the surface and let it dry for 48 hours. After the glue has dried I look for any voids that may need filling and do so with full strength Weldbond®. I allow the glue to fully dry (12 - 24 hours) before turning again.
Weldbond® is a Polyvinylacetate glue. It shrinks as it dries, it thins with water, until it has dried it cleans up with water, it has no solvent odors, it dries to a milky gray color which blends nicely with alabaster, and it retains some flexibility when dry (very important when gluing wood to stone). Weldbond® is available through Ace Hardware stores, (order number 18379 for 22 oz. or 18380 for a gallon) a gallon is $35-$40. Do I like this glue? - Yes. Here's a link to the Weldbond® site for more information about using this adhesive. "
Randy Gleckler
Charlie,
You do remember the medium we deal with literally does grow on trees right? At the point your at, even if it was a really nice piece of wood, I'd probably move on to another piece. Either completely toss it, or as I did with my last frustrating piece, set it high on a shelf until a light bulb (and I know you have many of those) goes off and tells you what to do with it.
charlie belden
I have an oil vacuum pump, a jiggle table (so you can vibrate out bubbles) with a neopreme pad for a good seal, and a lexan bell jar (all from my lost wax casting days). But the idea of immersing this piece in a resin and sucking air out so resin can get into every nook and cranny - exposed - just seems too messy. (This from a guy whose shop is much like an archeological dig, old unfinished, fossilized, pieces down in the Pre Cambrian Layer).
I want to finish this piece because the idea I have for it is topical. The piece is intended to be an Urn. The idea is to have four quarters next to it, 3 quarters together and one out front. From the void in the face of the earn, a hundred dollars in 20s, 10s and fives - $15 in front of the urn, the remainder sticking out of the void and out the top. The message "Taxes on EARNED Income vs UNURNED Income" The Worker paying 25% tax on his/her EARNED income, the UnUrned income taxed at just 15%. The worker is left with 75 Cents, the UnUrned income person left with 85 Dollars. Though the difference in the percentage of taxes is only 10%, the difference in After Taxes money is $84.25.
The question of the piece - Why is Earned income taxed at a higher rate than UnUrned income?
Anyway, here's what I've been working with
And here's the piece, before hollowing with 1 coat of wiped on thinned lacquer
If the idea for the piece weren't so relevant, I'd probably put this one on a shelf for who knows how long.
