Steve A- here is what we need *LINK*
http://www.youtube.com/watch?v=sjV9e-Lc4Js&feature=related
Re: Steve A- here is what we need *LINK*
I think it's funny that he's pedalling backwards?
steven antonucci
I think he could pedal normally if he took that twist out of the belt.
Would a Derailleur substitute as a VFD and where would you mount the shifter? (Pedal harder... I need more speed, Captain. I'm givin' 'er all she got!)
I can see mounting the lathe on the handlebars and sending the other guy home too...
Great possibilities.
Steve
Re: I think it's funny that he's pedalling backwar
Alan Zenreich
He is pedaling backwards because they reversed the seating on the bike and I guess those pedals work only in one directio (probably applies a brake if back pedaled). There are some notes to that effect below the video
BMX bike with coaster brake
steven antonucci
I didn't see the description, but upon looking at it again, that is a BMX frame, so it likely has the standard coaster brake for skidding and screwing up your back tire. I know a couple of guys in th bike shop that I worked in used to open the hubs and remove the part that locked it. The lazy ones would either weld it or replace it so they do tricks (like ride backwards).
It's been a very long time since I worked in the bike shop, but I've got a lot more tools and mechanical know-how these days. I think I could rig this up with my lathe and my trainer so that I could turn while pedaling... someday, I may just try it.
If I do, I'll be the first guy in a faceshield and bicycle helmet turning in lycra pants...
S
#5I want to make an ice cream maker
I keep my eyes peeled for the old fashioned hand crank ice cream makers. I'm going to set my bicycle on my trainer and run a spare chain from the free wheel to a sprocket welded to the ice cream maker. About 30 minutes of riding and will have burned enough calories to eat the ice cream.
#6Re: I want to make an ice cream maker
Dale Miner
That depends on the size of the bowl.
I have a couple of 5 gallon hand cranked freezers so when you get set up, a can assure you of a workout before the overindulgence.
#7Re: I want to make an ice cream maker
Carol Reed, Strawberry, AZ
John, I have always admired you for being teh ultimate multi-tasker, but this is a little over the top, even for you! LOL!
Yet If I had such a thing, I send it to you - and then drop by to help you eat it!
#8Re: I want to make an ice cream maker
Carol The ultimate way is liquid Nitrogen. Our chemistry students make such a thing and it's fabulous. It has the texture of soft serve but the flavor of real homemade ice cream. It takes about a minute or so to make.
That would just be an attachment to my pedi-lathe!
steven antonucci
hmm...
if you welded a different gear to either side of the hub, and ran one chain forward to the lathe and another bigger gear to the ice cream maker, you could truly multi-task!
Only issue might be that you'd need to make sure that the ice cream maker was well sealed, or you might end up with shavings in your soft serve!
S
#10Re: Steve A- here is what we need
Don Orr
It looked like the lathe was turning the wrong way to me.
