Veritas - Innovation in Tools
Veritas Scraper Burnisher..
Dave Winters
..Anybody use one? Or is there a less expensive MacGyver version?
Thanks!!
Dave
Re: Veritas Scraper Burnisher..
robo hippy
I use a standard triangle burnisher for card scrapers. It doesn't take much pressure, and a few gentle strokes will give you a nice burr. Keep the burnisher at 90 degrees to the top/bottom of the scraper. I do some times hit the top surface of the scraper first, with the burnisher at about 10 degrees to horizontal. This is what you do if you want to return the burr. I found out long ago that my card scrapers generally had a better burr if I did this first. Most of the time, I just use the burr from the grinder. I do have CBN wheels, both D Way, and some matrix ones that I have had for 6 years. They do leave a better burr than the standard aluminum oxide wheels. when sharpening them, I do push into the wheel a bit rather than just kissing the bevel. Bevel angle for me is about 75 degrees.
robo hippy
Bill Neddow
I use the Veritas ones -- mainly because the Lee Valley headquarters is just down the road from me. I think any cabinet scraper with good steel will work for our needs. I use them particularly on wet wood where the grit in sandpaper would get clogged quickly. They are really effective.
Dave are you talking about the burnisher for putting a burr on turning scrapers or the burnisher for putting a burr on the cabinet scrapers.
I use the Lee Valley version for my cabinet scrapers however for many years I just used the tang of a drill bit to do the same thing. I'm not sure why they made it 6 or 7" long. You only use a small portion.
I made my own version of the turning tool scraper. I gave it away. It didn't do anything that my diamond hones don't do. I like the diamond hones because I can choose the size of the burr. The ultra fine hone makes an extremely small burr and the medium and course make a larger burr.
The turning tool scraper is quicker for large round nose scrapers. However you have to polish off the original burr before applying a new one and since you already have the diamond hone in your hand it's just as easy to just use it.
Steven Antonucci
I made one out of a small carbide rod ($2)
steven antonucci
if memory serves me well... I think I bought it from Enco?
I use diamond hones to polish the top of my scraper to a mirror finish. I also use a diamond hone on the bevel to refine the edge. Like John Lucas, sometimes, this is the burr I use to cut with. Other times, I will use the carbide rod to make a larger burr.
Used properly, the result is stunning.
Steve
Mike Stafford
I think he is referring to..... *LINK*
Mike Stafford
Lee Valley turning tool scraper burnisher. See the link below.
I have one but don't use it anymore. When I first started turning I used my scrapers much more than I do now and thought that the burr was essential.
Now I sharpen on the grinder and immediately dress the top surface of the tool with a fine diamond hone and remove the burr. This results in a tiny negative rake which I think it cuts better without the burr and is less prone to self feeding.
Lee Valley Turning Tool Scraper Burnisher
Re: I think he is referring to.....
Yea that's what I thought and what I built. I simply took some drill rod and turned a cone with a tenon on the bottom. I was learning to do press fit tolerances so I turned the tenon the same size as a hole in my steel plate and then cooled it the freezer until it dropped in. When it expanded it was locked in place. I did harden the tapered pin first. I don't know if Lee Valley's is hardened but figured it would work better if it was at least as hard as my turning tools.
I made one . . .
Doc Green
similar to the Veritas using 3/4" plywood and 5/16" steel pins (hardened) that I had in my stash of trash. I simply drilled 5/16" holes in the plywood and dropped the pins in.
Two pins: one does the burnishing and the other serves as a pivot. Multiple holes allow me to move the pins around as need be.
My pins are straight. I see no need for them to be tapered.
I'm told that you can buy hardened steel pins at a hardware store. Don't remember who told me, but maybe the teller will provide more details.
~Doc
Re: I made one . . .
Dave Winters
O.K.! Thanks for all the replies. I was asking about the turning burnisher. I make resin necklace pendants and use a little negative rake scraper...seems to cut the resin really sweet if I grind and then make a burr on the end with a hss router bit shank, but I think I'll make a homebrew one and see how that goes.
As always, many thanks for the help!
Dave
