Reading the life story of a tree, in it's rings.
Keith Newton
I was wondering if any others of you who harvest your own wood, then go through the process of turning a tree into either functional, or art objects, enjoy studying the rings and defects recorded in the rings?
Is there much written on this among TURNERS? I am well aware of dendrochronology, but think there is room for lots of interpretation beyond that.
I have been studying / enjoying this for about twenty years, and wondering if others of you have an intrest in this as well?
I'm starting into a tree, growing about 15 miles from my birthplace, and about half that from my Mom's homeplace, which was 98 years ago. I'm still acquainted with a lot of older folks, whom I can dig information from for certain marker / epic years.
Has this been done, and are any of you interested in this, or have suggestions for where to publish it?
I love old trees. If any of you know of any articles like this, please send me a link, so I can try to not be redundant. Thanks, K
Re: Reading the life story of a tree, in it's rings.
Rob Wallace
Rob Wallace
Keith:
One of the courses I teach here at Iowa State Univ. is "Biogeography" - the study of the geographic distribution and processes which give rise to the distribution of organisms on Earth. Among the many methods used to study these processes, habitats, and past conditions is the use of tree ring data.
A method used to infer relatively recent past climate is to analyze tree rings of long-lived trees (but not just determining their age by simple ring counting; = "aging" the trees using classic dendrochronology methods, either with full slabs or increment borer cores), but by doing correlation studies of multiple samples of tree ring width to determine "abundant" growth years, and to identify those years that the trees were stressed (and thus had correspondingly slower growth rates). It is then possible to infer "good years" and "bad years" using such "proxy" data from the trees, which can be helpful in determining tree migration, reproduction, establishment, and associated vegetation abundance. It is also possible to extrapolate this kind of data to broader predictions about climate and events such as El Nino, very wet or dry periods, regional climate shifts, etc. Tree samples can be radiocarbon dated with fairly accurate dates that go back about 35,000 years or so....
I'm not sure this is the kind of information you are looking for, but this source of data is well-established in the study of recent paleoclimate.
Rob Wallace
Keith Newton
Thanks for the response Rob, but I will have a little tighter focus in things that happened to this individual tree. I already know about some of those stress marker years, but this tree would be a sorry candidate to be included in a treering study. It started life in the front yard of an old homeplace. But the fields had grown into a forest, recently clear-cut, then the debris burned, which killed all the vines that had been smothering it.
This is the tree that I sent you a photo of a few weeks ago under the thousand canker heading.
I'm not sure what I will find in this tree. One thing that already has my intrest, is sapwood into heartwood transition, not following the annual rings.
Of course, lightning strikes, and torn off limbs would be weather related. And then there is ring shake that I find interesting.
My thumb typing is slow on the iPhone. My computer froze yesterday. My camera and my old buddy Burl both gave it up the week before. Burl was about seventy, dog years.
Carole Valentine
I have always taken a pretty close look at the stump when I have had to cut a tree here, not only to estimate the age, but to get an indication of the tree's struggles over the years. Some things I can trace, most I can't without going into archived weather records, etc. For example, I had to take a tall pine out last year that was a little too close to the house. I could see the year the house was built...the annual rings nearly doubled in size when the lot was cleared and the tree no longer had to compete for sunlight and began to really grow. At least I assume that was the case since I know when the house was built. They certainly have their stories to tell.
Jorge Castañeda
Keith,
I recently turned a bowl from a chunk of an ancient sugar maple tree in the front yard of a friends home. Although not a big chunk, the resulting bowl was 11" x 6.5", 5 pieces of metal were found in different locations, and this piece was near but above the crotch, some 9" above the ground. Maybe a boy playing?
The metal leaves a marker, black streaks...
R Henrickson
Last year I turned a large ash bowl. There were a number of odd stains rising vertically through the log, all apparently at about the same growth ring. In the course of rough turning I saw something very small but bright and metallic when I stopped the lathe; I had felt nothing. Round cross-section. Decided, perhaps not too brightly, to take another very light cut. It disappeared, but left a hemispherical depression. I continued, and found another and another. It turned out (!) that the tree had been hit by a load of No 7 or 7 1/2 buckshot (identified by my hunting brother-in-law) when it was about 60 years old, then grew for another 80 years. Final diameter of the tree was 16-18".
charlie belden
When you START with a tree and examine pieces as they are cut you get a much better understanding of how much of it's life history is recorded in its wood and how it has reacted to its environment over time. With that understanding comes a real appreciation of just how amazing trees are. To take sunlight, air and water and build a structure that is not only mechanically strong, an amazing chemical factory nut also often beautiful . . .
George Nakashima wrote a book, The Soul of a Tree you should probably go through. He traveled the world to see and sketch magnificent trees. Few woodworkers have the understanding of trees that Nakashimia acquired over a lifetime. And few woodworkers have the ability to show the beauty and strength of this wonderful material - as Nakshima did.
We have a lot of eucalyptus trees here in Northern California. One type of eucalyptus sheds its bark continuously, revealing what I see as its musculature. Rippling compression rings bearing the weight of a huge branch, tendon and sinew like surfaces pulling against gravity on the uphill side of its trunk and roots at the ground, resisting forces attempting to fell it, old injuries healed over and enveloped. And with an understanding of the forces its wood resisted, one can imagine better the flow of the grain beneath the bark and the built up forces waiting to be released.
The most amazing grain is found where the trunk meets the roots - where the tree's anatomy really deals with the forces exerted on it - or in a Y crotch where gravity wants to pull the branches apart - and the tree finds ways to overcome those forces and continue its climb to sunlight - or around a place where a past windstorm or snow load has torn off a branch and the tree heals around the wound.
It's difficult to understand the context of a piece of wood, nor imagine the tree from whence it came when you have only a relatively small piece to go on.
Mahogany is a fantastic wood to work with edged tools. But to stand amidst one's buttressed roots, almost enveloped by them, and crain your neck looking up, up, up . . .
To sit in a crotch of a big mango tree, nestled by its branches - 20 feet off the ground - enjoying a carefully selected, just picked, ripe, sweet, juicy mango . . .
Trees record their history within themselves. We're stuck with just photos, movies, videos - and memories.
Your post triggered a lot of memories, almost forgotten. Thanks.
(think I'll go sit up in the big pepper tree out back, look up at the redwood tree next to the house and remember trees I've known)
Thanks Charlie, I bought Soul of a Tree,
Keith Newton
When it first came out.
Your thoughts of redwoods reminded me of a book I'll bet you would like. Have you read "Wild Trees"?
