Design Softwear
Design Softwear
Design Softwear
To Minehan
I find I have a difficult time creating a design in my head, puting some detail on paper, and creating it on the lathe. I know there are software programs to create the design and get it on paper. Does anyone have experience using these programs.?
Re: Design Softwear
Re: Design Softwear
To Minehan
The name should be Tom not To
Re: Design Softwear
Re: Design Softwear
charlie belden
Are you looking for a program
to help you develop the profile of a piece as a line drawing,
one that does that to scale so you can take dimensions from it and and transfer to a blank
one that you can create a virtual 3D model you can see at any angle
2D drawing programs will do for developing profiles as line drawings (Corel Draw)
2D "drafting software" that you can use to create scaled drawings - Turbo CAD will do
3D - Google's SketchUp is free and it lets you create a profile for a piece then "turn it"
to create a 3D model. You can also do all that to scale and take dimensions from a printed
copy of the profile and transfer them to your blank.
To do variations of a piece you have a profile photo of, PhotoShop, Elements, Paint Shop Pro
of the free open source program GIMP will let you do variations of proportions of all or part
of your original image and let you taper all or part of your image.
(see earlier thread on PhotoShop as a Design Tool
or
Get a pad of Quad Pad (1/4 grid graph paper), a 0.5 mm mechanical pencil, compass
and a set of French Curves and play with them.
Re: Design Softwear
Re: Design Softwear *LINK*
Juergen
Check out Bill Ooms Website: http://software.billooms.com He does complex segmented pieces and Rose engine work. He's developed several pieces of software to visualize and modify a design. The link below is a 3D program for bowls, hollow forms and platters
Bowl shape software
Re: Design Softwear
Re: Design Softwear
Stuart Johnson
I use Lloyd Johnson's WoodTurnerPro for most of my segmented layouts but also like Sketchup. Using SU with the Bezier Curve plug in found here:
http://forums.sketchucation.com/viewtopic.php?t=13563 will help in achieving nice curves. I also use a grid plug in to help with segment size but can't find the download link right off. If you are interested I'll see if I can find it.
