I got a couple of the inlay kits, and they do not recommend squaring the blanks with a pen mill, sure could use some input on alternate ways to square the blank, and how to hold/support the blank during the process. Don't want to ruin my progress, so asking in advance. thanks for the input. Dennis
This is dependent on what resources you have in your shop.
My opinion is to use "sanding" so do it.
What I did:
On my 1" belt sander I clamped a piece of aluminium extrusion on the table making sure it was 90 deg to the surface of the sanding belt. Then I placed a machinist "V" block against the extrusion and clamped it in place. I put the V block as close as I could to the belt but made sure sanding belt didn't hit it. Then I could cut off the pen blank with a extremely fine saw blade in dremel but left about 1/8 inch to be sanded down to brass tube making sure it just barely made the end of the brass shiny.
Taking you time lining up all of this is the most important part of the job. I had multiple of this to do for presents so it was worth the effort.
You can substitute any of the above with items you have, like wooden board with straight side for the extrusion, make your own V block etc.
This is also very good way to do extremely figured blanks also.
When not using a pen mill, I too use the Penn State jig on a disc sander.
The problem with the other approaches mentioned is that your goal is NOT to square the end of the blank relative to the side of the blank. The goal is to square then end of the blank relative to the glued in tube, which likely is not absolutely parallel to the sides of the blank.
So the reasonable approach is to register the jig inside the tube, as the PSI approach does.
Another approach is to put some sandpaper on a faceplate on the headstock of your lathe and put a transfer punch or drill bit (that is just slightly smaller than the inside of the tube) into a Jacobs chuck in the tailstock. Then slide the blank over the transfer punch and then bring the to stock near the headstock. Then you can sand the end of the blank knowing that it is square to the tube.
Alan, thanks for the info. I tried the idea of the transfer punch, problem being is my faceplate has a hole in the center of course, and can not seem to get the paper to cooperate, maybe I need to use something besides 120 grit, with a thicker backing? Dennis
Your face plate will not have a hole in the center if you mount a piece of wood on it, face it off, couple of coats of poly and your sanding disc will stick just fine.
If your pen mill has the removable cutter head, turn it over so the flat is towards the pen blank. Place a small disc of psa sand paper on the flat and it will register square to the blank. Slow but works with nothing to buy.
DUH! That for the tips, I tried both of them, slow but works, I had a set of transfer punches, so it worked fine. I used 80 grit, at 500 or so rpm, slow but it did the trick, if I was doing 50 at a time, it would be slow, but it worked great. thanks to all those that replied. Dennis
