faceplate rings
Darrin Hill
anyone use them and can u get generic ones?
faceplate rings
Darrin Hill
Re: faceplate rings
Jeff Willaford
I use a couple of sizes of the Nova faceplate rings and have been happy with them. Don't know of any generic rings.
Re: faceplate rings
Colin
I don't know of any generic ones as the angle on each manufacturers jaws seems to vary I expect it will be difficult to find any. I have the Axminster ones for my Axminster chucks and am very please with the.
Re: faceplate rings
Peter Charles Fagg (UK)
I use faceplate rings all the time and over the years I have acquired several different manufacturers makes, Selbix and Axminster, for example.
I still use them but on my Versachuck.
Not sure if the angle is that important as long as they are secure and do the job!
Regards Peter.
Re: faceplate rings
Walt Bennett
I've several Technatool ones and use them frequently. Never had any problem at all. Don't know of any generic ones, sorry.
Re: faceplate rings -- Why
Stuart Johnson
What are the advantages of using a faceplate ring over a faceplate?
Re: faceplate rings
Carole Valentine
I would not be without my Teknatool faceplate rings. The main reason is because I often start a piece and for whatever reason don't want to finish it until a later date. The ring stays right on the piece (freeing the chuck for other work) and it remounts in the chuck perfectly, unlike if you have turned a tenon and removed it from the chuck then try to remount.
Re: faceplate rings
Jorge Castañeda
I do use Vicmarc faceplate rings, with my Vicmarc chuck. They work good. For big work I use a real faceplate.
Re: faceplate rings
Don at Central Illinois
That was a question I was going to bring up. Is there a maximum diameter, weight, etc. where you can use the rings versus a regular face plate. I just bought a larger lathe (stealth glout) but the spindle is 1 1/4" not 1". I can buy an insert for one chuck and was thinking about the rings instead of more faceplates. Curious.
Spindle adapter ?
Doc Green
Don, you know you can get a spindle adapter that will convert 1 1/4 to 1" ?
I have one of those 1 1/4 to 1
Ken Vaughan
I am not Don -- but have one of those.
There are several vendors who sell those. I think I got mine from Amazon. Handy to allow things to move from the Club mini lathes over to my big lathe and vice versa
Re: faceplate rings
Grant Wilkinson
I've never used them, but I wonder if you would know if there is any change of damaging the chuck jaws by tightening them onto metal, instead of wood.
Re: faceplate rings
Carole Valentine
Not that I have seen. HOWEVER, the rings are made for specific chucks and jaws. For instance the Nova rings match the dovetail profile of the jaws they are made for. If you used a Nova ring on a non-Nova chuck, or even on a Nova chuck with other than the specified jaws, I would say there is a good probability of damage.
Re: faceplate rings
Grant Wilkinson
Thanks, Carole. I use Oneway chucks, and while Oneway has faceplate rings, they are not for use with their chucks. They have a spindle fixture that the rings lock onto.
Re: faceplate rings
Carole Valentine
Ah yeah, that's right. Forgot about how the Oneway rings work.
Re: Spindle adapter ?
I've already thought about that, but I think that if I buy a new insert for my big chuck it would be closer to the headstock and less chance of wobble. Will probably get at least one adapter for some faceplates until I can afford new faceplates.
