Anyone use a Baldor 8100W?
steve worcester
I decided to upgrade to an 8100W, and because of the guards (the exhaust shoot comes down at an angle), the grinding jigs will sit too far below center. You can't take the guards off because the hold the spindle in place.
One option is to lift the rear up about 3 inches and to put blocks under the jigs to raise them up. Another option is to make a new platform for the Oneway grinding setup that would be a longer arm and raise it up.
Anyone run across this yet?
Re: Anyone use a Baldor 8100W?
robo hippy
Steve,
I have been using one for years. I don't have the Oneway set up for sharpening. I had an Ellsworth jig, but switched to platform sharpening. Much faster and simpler. I have heard of people setting them up for the Wolverine system. The outside guard can be removed no problem. I took mine off to accommodate my D Way CBN wheels (note, there is a pin on the motor shaft to key into the spacer/washer for supporting the grinding wheels, I left it on, but heard of some one who ground it off so the outside guard could be put back on, and I could see no other way to remove the pin). I looked at the inside guard, and can't really tell. I don't see a problem with tipping the motor forward, but that would have the exhaust chute more level. I have noticed with mine that they collect dust and filings any way.
In looking at the Wolverine system, I think being able to raise or lower the platform would be handy. Some other systems do have that ability.
robo hippy
steve worcester
I have the DWAY wheels too. Got the new spacers, with two washers on the inside of the wheel and one on the outside, I have clearance and can use the guards. Three washers on the inside would probably center the wheel in the guards (or would wheel covers be a more appropriate name). The exhaust chute is molded into both pieces of the guard, so if I want to fit the Oneway bases underneath them, I will have to tilt the back up (about 3") to level out the exhaust chutes and then put an MDF platform of about 2 1/4" under the bases to raise them up.
robo hippy
I built a platform up about 2 1/4 inches for my platform to sit on. Motor sits level. The 80 grit wheel takes off steel faster than the wheels that came with the grinder (30 and 60 or 80 grit, can't remember). The 180 grit cut more like 120 or so. They still cut very fast, but the polish on the bevels is looking smoother. You will love the way the motor and wheels run together. Never have to think about bolting it down. I have mine bolted to some ply wood for when I am hauling it to a demo. I do have to put some plywood behind the motor for when it is on the hand truck, else wise, it tips backwards at a fair angle and wants to push off bottom wise.
robo hippy
robo hippy
Steve,
Just as an after thought, if you are going to be in San Jose next summer, I will look you up and teach you how to platform sharpen. Much easier!
robo hippy
steve worcester
In this case, without tilting the whole grinder forward, at level with the platform, I can't get the platform above center.
Those cheap grinders......!!
Barou
I was able to loosen the bolts holding the guards in place and rotate both of the guards (left and right) to get almost enough clearance. Also had to grind a little off the top of the Wolverine receiver tubes.
Re: Good Grief! That's twice ...
Doc Green
... what I paid for my first lathe!
steve worcester
Add the CBN wheels, and it goes well over my first lathe purchase.
But here is a side view that shows the issue I am referring to. Note the angle of the exhaust chutes.
From what I can figure, I will need to tilt it forward and put some risers under the Oneway bases and make a longer arm for the platform. I want the platform to be at wheel center or above, when parallel to the base. I would run it without the wheel guards (covers) but they have made them an integral part of the spindle.
Chuck Bjorgen
Steve -- That just doesn't look right. If you look on Baldor's web site for your model number, it shows the bottom edge of the wheel guards parallel to the base of the motor. I wonder if those guards were mounted wrong at the factory?
Bill Gasper
Steve,
I have a 1/2 year old grinder like yours. There are four long bolts that hold the the ends of the grinder to the motor. If you loosen the nuts you can rotate both wheel guards together and reorient the exhaust ports farther up so there is additional clearance for the Wolverine receivers under the guards. I added a 1" block between the Wolverine and the plywood base of the grinder assembly. The flat rest is not quite on centerline of the wheels but maybe 3/4" down. This works pretty good. Sorry no pix.
Bill
Bill Gasper
Got some photos of my grinder showing the modifications. You'll see a riser block for a Tormek attachment.
robo hippy
Bill,
I don't use the Wolverine, but that looks like a good idea. I will have to check it out.
robo hippy
Steve Worcester
Thanks, that was the magic trick I was looking for!
steve worcester
I got it all setup, after wooden malletting (verb-I think) the wheel guards, I am able to get 2x3/4" MDF chunks under the Oneway doohickeys. All lined up and I really can stand a nickel on top of it while it runs. And it doesn't fall over (the nickel).
I will have to make a longer platform arm, in time and as welding skills increase.
Thanks all for the assists. With the Baldor 8100W and DWAY CBN wheels, I can't think of a more pimped out grinder setup.
robo hippy
A more pimped out grinder set up??? Steve, did you see Stuart Batty's Omni Grinder? I thought my tool lust had subsided. That tool, well, drool..........
robo hippy
ambrosia aple riser block.. wow
steve worcester
I saw it, a steam punkish looking design. Looks real cool.
