Morse taper Maintenance
Philip Duffy
Having seen a bit of galling inside my PM tailstock and having noticed that the Jacobs chuck was slipping more than expected I removed the tailstock sleeve entirely - - just extended it all the way and pulled it out. Calling a Machinest friend he suggested I turn it slowly in the headstock and run some abrasive paper on a stick inside to clean it all out. So, I reversed the normal direction of the sleeve, mounted it on the Inside jaws of my Nova - -held very lightly, and used a pointed stick to work the 220 and then 320 inside. Well, what a nice surprise! The end result is a nice clean and very well holding tailstock. With all the safety concerns expressed on this form lately, I need to caution you that if your lathe does not go very slow -- about 20rpm, then leave it alone!! I recently tried to purchase a MT cleaning tool only to find out they are not offered by WCraft any longer. My machinist friend says he has a reamer that size and I will borrow it next visit. Meanwhile The holding capability is much improved and I suggest we all take a look at those MT2 fitting to see if they are clean. Philip
Re: Morse taper Maintenance
Re: Morse taper Maintenance *LINK*
Bill Turpin in WNC mountains
Packards still carries a taper cleaner. Mine works well.
Packard's
Don Evans
Phillip, your machinist friend is right about keeping the MT clean but for others let me point out that there is a difference between using a reamer verse the cleaner that Bill pointed out.
You should NOT use a reamer for cleaning an MT, but use it only when the surface area of the MT has been damaged. As you stated that your MT is galled then a reamer is the thing to use. When the thing has matter such as grease, oil and dirt only then a cleaning tool is the answer.
Understand that the reamer removes metal and will make your MT accessories seat further down into the spindle or quill of the tailrest and over using the reamer will eventually result in having to replace the spindle or quill.
I have the green cleaner that Bill pointed out and it is made of a plastic material to ensure it doesn't marr the surface but only cleans it for reason just stated.
For just cleaning a twisted paper towel with some solvent (use sparingly) will also work if no cleaning tool handy.
Use that reamer very gently as you can hang it up, then you're really up the creek.
Don
And NEVER use a reamer on the .....
JamieDonaldson
..Morse taper with the lathe turned on! Most reamers have a handle that provides leverage to turn it by hand, and if it catches under power it will result in severe damage to both hand and spindle taper.
