turning pencils
I got the pencils all glued up the other night. That was challenging. They float in epoxy so I had to rig up ways to hold them down while I was trying to pour in more epoxy. Next time (if there is one) I think I'll glue the pencils down with a thin layer. Once that is tacky I'll pour in the rest.
The two bowls glued up pretty well. I don't know about the spindle. I tried to put two lengths in a pvc tube. Worked well when dry, not so well when I poured in some epoxy and then tried to put the pencils in. I'll see how that looks once I turn away the Pvc.
I started turning one bowl. It's challenging, hard epoxy mixed with very soft pencil and even softer lead. I did find that rubbing the bevel smears the lead. OK when your turning the shape but you have to go back and scrape. The new Hunter Hercules did a good job. I mixed it with using the bowl gouge to get the shape optimum and then clean up with the Hercules.
I hope to finish these by the weekend so I'll try to post photos next week.
