Axminster Chucks
Axminster Chucks
Axminster Chucks
mark j. thill
Has anyone had any experience with Axminster chucks from the UK ?
Re: Axminster Chucks
Mike Foster
I have a couple of axminster chucks. One of their top end chucks, and one of the middle of the road. Can't remember their names. I like, and use, them both all the time. The real reason I like them over other chucks is that it is really easy to change jaws. They machine their chucks to accept jaw that mount on slides which are completely interchangeable. I always buy a set of slides if I buy a new set of jaws. It is more expensive, but soooo much easier to change jaws. I just spin a set of jaws off, and spin another set in. No messing with allen screws or losing them in the shavings on the floor. The big chuck is not quite as beefy as a vicmark, but I have yet to find something that I can't chuck up in it. They also offer a much larger variety of jaws than most other chucks. I'm a satisfied user, but take that FWIW.
Bill Turpin in WNC mountains
I own two, love one and hate the other. Have one on wifes mini lathe. The jaws that came on it have convex jaws. This allows registration in a 3/8" cove. Remove the workpiece and replace it without wobble. Very good and happy. Ordered a larger version for PM3520B. The jaws have a actual less grip range than smaller chuck. Axminster shipped it airmail for $69 freight plus $29 import duty. My $300 (comprable to SN2 or Stronghold) chuck cost over $550.
DO NOT BUY UNLESS YOU CAN GET IT IN AMERICA. They are good chucks in the medium size.
ebd
Re: Axminster Chucks *LINK*
ebd
I would disagree. I have 2 or 3 of the precision chucks and 1 of the smaller size. I find all quite precise. YOu do have to make sure to get the right jaw in the right slot (I too buy additional slides). I have found them to grip anything I can throw their way.
I also found it hard to get them and accssories in the US. Craft Supplies used to carry them but as far as I know phased them out. The only other source I had went out of business (retired I think).
One thing you might consider is the VersaChuck. Same as the Axminster with some additional versitility.
As an aside, Axminster didn't make the Axminster chucks. They were made for Axminster by a firm in Poland under the brand Buffalo and stamped and packaged Axminster. I've several times tried to track down the manufacturer without luck.
VersaChuck
I did not say that they weren't accurate. After several years of using the smaller chuck, we had nany jigs and jamb chucks. They are too large to fit in the larger chuck. The new chuck's grip range is about 5% smaller than the old one. I was complaining about the grip range and the cost of a direct buy. The grip range of the larger chuck should be 25 to 50% greater, not smaller.
