Green, Dry or In Between?
charlie belden
Turned a piece of green Bay Laurel (aka Oregon Myrtle) root burl - and one went a little oval and leaned a bit, another I blew out through the side and the piece went Raisen on me - deforming a LOT. Having turned a piece of DRY madrone arial burl - and gotten beaten up a little in the process, I decided to try In Between - not green, but not dry.
Thankfully, there's no Woman of The House around to tell me not to use the microwave to dry out wood. So 3 minutes in the microwave, 30 minutes of rest/cooling - repeated probably 10 times over a day's time and I had a block of In Between for a small 3 3/4" diameter x 4" tall hollow form with a 1" opening in the top.
Wonder of wonders, it barely deformed, though some small cracks did appear and the turning ws quicker and easier than turning DRY.
Will bleach this one with peroxide several times and then see if I can "pop the grain" a bit. Have a reddish brown alcohol dye from Madder Root and some yellow organge alcohol dye from Spanish Saffron I want to play with. Have absolutely no idea how that will turn out.
Anyway, here's the hollow form - without any make up.
