ADVERTISE HERE - FREE TRIAL
sorby frustrations
sorby frustrations
sorby frustrations
Darrin Hill
i hate metric.. well.. maybe it just annoys me.
Sorby's hollowmasters have an allen screw and for some reason i always use the one size up, which strips the inside of the hole. Can i just find some metric screw that i can use a phillips head screw?
Want to change cutters on some and sharpen ohters, but all my screws are stripped now and i cant get them off..
Re: sorby frustrations
Doc Green
The screws in mine are 10-32 with 1/8" Allen drive. Can't get much more un-metric than that.
Philip Duffy
Metric allen screws are commonly available at all hardware stores. As a fan of metric, I think we should all be trying to use this simple and easy-to-use system. Phil
Don Evans
Your problem may come from not taking care of worn allen wrenches. Allen's tend to be softer than the screw which is good as they don't damage the screw BUT that is only if the wrench is well maintained. You repair your wrenches by grinding the end off of them so that the end has sharp corners that go down into the screw head. After a few uses of a wrench, especially if used on over tightened screws, they should be reground. Also, lightly remove any bur created using a file, do this in a direction that doesn't round the corners, sandpaper works well also for this and less likely to damage the wrench.
Do this by touching lightly the flat end of the wrench to the grinding wheel and grinding it back slightly.
I keep a set of SAE and METRIC wrenches on hand and if don't know what size screw I'm dealing with I'll try both sets to see which has a wrench that fits screw the best, do this by going by how much play wrench has without moving screw.
Using a worn wrench will screw up a screw quickly :(
You may find that doing this now may allow you to get the screw out you are having trouble with.
Don
Don Evans
I should also add that I use vise grips to hold the wrench when doing this and the grinder table for support, WEAR EYE protection, faceshield is best as slightly too much pressure on wheel can take wrench away in blink of eye.
Don
The best solution for this problem.....
JamieDonaldson
...of endless searching for the right individual allen wrench is to buy a bound set of metric and SAE from a dealer like Sears and keep them handy at the workbench. Since they are fastened together it's very quick to find the right size, and I even mark the frequently used sizes with a dab of color coded paint.
Bill Turpin in WNC mountains
I agree with everything that Don says. I want to add: Do not get the wrench hot when grinding a new end. Keep it cool (below 250° F) or you will start to change the temper and soften it. Softening will accelerate the problem you are trying to fix. Use many short bursts on the wheel. Most all set screws on imported lathes are metric.
10-32 phillips head in my multi-tool
Craig Daymon
I'm pretty sure that's the same for your hollowmaster, thread-wise. I replaced the allen screw after wearing out the socket. I don't know about the wrench discussion, but I always like to get an appropriate size T-handle allen wrench for tightening these. I have better luck with them than the ones that come with the tool. I usually get them from McMaster-Carr.
-Craig
