A teaching epiphany: Bowls and beads
steven antonucci
Earlier this year when I taught my third installment of Intro to Woodturning at Peters Valley, I had an epiphany. All woodturning can be dumbed down to a few simple things. Here is the most profound of these things:
A bowl is just a bead with a cove inside of it.
(T-shirts coming soon...!)
If you take a piece of wood and mount is in spindle orientation between centers, cutting beads and coves is usually very simple to explain. If you want to turn a bead, you start in the center and work center-left and then center right. To turn a cove, you work left-center and then right-center. In either case, the goal should be to keep a consistent cut pace (i.e. same sized curl for the whole cut). On a bead, this means removing the corners first and sneaking up on the final shape in 2-3 passes. On a cove, this means cutting out the middle first, and then sneaking up on the final shape in 2-3 passes. (See John's video)
So what does this have to do with cutting a bowl?
In a typical bow, the grain runs perpendicular to the lathe axis, but it does not mean that the rules of grain direction change at all! The outside of a bowl is a bead, which means you cut from the foot to the rim as if you were cutting a bead. You end up getting both sides of the bead, which is probably a good thing because you don't have to fuss with making them symmetrical.
The inside of a bowl is just a cove cut on the left side, which means you should cut from the rim to the foot as you would cut a cove in a spindle turning. When the wood is oriented in face grain position, you cut both sides of the bead and cove at the same time, and only have to get it right one time instead of twice (and matched!)
(if you look at the drawing, all I did was reorient my notebook like I did with the wood on the lathe. The arrow do not move because the "right direction" or "with the grain" is a constant.
Once you understand this, you can do anything on a lathe (with a sharp tool and a lot of practice...)
Steven
