need to sit to turn
bill w
I want to learn to turn, but can't stand very long. Any suggestions.
need to sit to turn
bill w
Re: need to sit to turn
Fred Holder
There are several lathes on the market designed for people to sit down to turn, they are all pretty expensive. Since you are just wanting to learn to turn, I would suggest that you mount one of the small lathes, such as a Jet 10-18 on a platform that will tilt the lathe to about 45 degrees and with room underneath for your legs to fit under. Make this angle adjustable to fit your particular lathe and your body. This would give you something to learn on. If you then decide to go for a larger lathe, Oneway, Vicmarc, and perhaps others make sit down lathes.
What Fred said.
Oneway makes a rather expensive "sit down" lathe. I've seen and used the one over at the Folkschool. Nice lathe - called the 1236 SD. But as Fred suggested, get a small mini lathe and mount it so you can sit. After you've caught the bug, go to a bigger lathe.
It also depends on what you want to turn. If all you are turning is small objects and bowls, you could mount any of the smaller lathes such as the Delta 46-460 or the Jet mini lathes on a suitable platform or surface. It would have to be fairly stable, of course.
Jim H
Hi Bill,
I turn from a wheelchair. I have a jet Midi-VS on a jet stand with the bed extension.
I have modified the Jet stand by cutting the uprights down so that the motor just clears my knees when I roll under the bed. I have also moved the cross bar back with some homemade braces to give me more clearance for my legs.
I have not as yet tilted it, but am considering that. Be very aware that turning from a sitting position puts your face very close to the action. I believe a high quality face shield is a must!
We have another gentleman here that turns on a Nova DVR. I believe he has his on a homemade stand.
Don’t know what you are wanting to turn or what you are willing to spend but I was talking with Brent English from Robust at SWAT. He showed me some preliminary drawings of the Robust Liberty modified into a sit-down, tilting lathe. I have been having dreams/ fantasies about it for a week now he got my mouth watering so bad ;-)
I honestly don’t think I can afford it anytime soon, but if the quality is as good as the rest of the Robust line it will be worth every penny, and will be on my wish list.
I am a new turner, but if I can help out or you want any pictures of my setup let me know.
j@mbgtx.com
Phil Miller
I have designed a stand to sit and turn and I can fit it to the new Delta Mini and Jet and I just did an older delta mini. I have shown this to Delta and that will be in the future. I have tested this with fellow turner here in our club you can see it at;http://iluv2turn.com/delta-lathe.html want more info call me at 608-792-1497 Phil
arthur in LA
I made a stand for my jet mini, so I could sit. I was turning a lot of small things for craft shows. I have spent many hours, many years standing at the lathe and one thing that surprised me was, all of the shavings which used to go on the floor now all ended up in my lap. so be prepared for that. I did not use a chair on casters and found that I was always try to inch the chair closer to the lathe. I thought several times about looking into drawer slides that were heavy enough to allow me to bring the lathe to me.
I did like the break of being able to sit to turn.
Jim H
Can't help with the rolling on shavings as the the larger wheels on my chair handle them well. I did however have a issue with tons of shavings on my lap. I solved that with a turning smock ( I just got a new one that is hand made by a lady that is cool, and sheds the shavings incredibly well, can get the name tomorrow if anyone wants it) I also clip a thin cotton sheet to the arms of the chair, over my lap. It does a great job of keeping them off me.
bill w
Thanks for all the great info. Will look at a jet mini for now. If I get good I will look at a robust or oneway.
john lopez
Legendary turner the late Rude Osolnik had a zillion tools hung on a studio wall in seemingly random order.
http://rudeosolnik.com/?q=remembering
Looking at his order from chaos made me more at ease in my own work space.
For mobility reasons I keep mine in a somewhat more orderly fashion
when I don't use the lathe.
But when I am working things end up everywhere.
If I have to move away while turning finding the the sweet spot
again on the tool (and mentally too) can sometimes be a long way back.
I drop so many things that I have some tools in duplicate
just to avoid the detour involved with picking them up.
A powerful magnet on a heavy duty aluminum grabber ,
never one of those plastic pieces of junk from the drugstore !
It's the act of moving away.
Kind of hard to explain (or at least to put in writing)
With more experience as turner you may understand.
It's much like loosing your place when you are reading an exciting book.
And I don't mean to suggest you go out and buy two of everything.
Pay attention to your spindle height because neck & shoulder pain
can and will keep you out of the game.
Master turner David Ellsworth devotes an entire chapter to the body in his book
titled Ellsworth On Turning.
Correct posture and positioning can make a huge difference.
As Jim H. mentions a seated turner works with his face closer to
the spinning workpiece and things do come free sometimes.
Full face and dust protection is common sense.
Not taking care of yourself can ultimately mean less shop time
due to health problems.
Learn safe techniques and have fun.
I do all my turning from a chair.
Pick the chair you work from carefully, it too can make a difference,
not only in the quality of your work but safety and fatigue levels as well.
