What is the best way to ...
Ed Moore in SW VA
learn how to use an airbrush correctly? And what is considered to be a good airbrush?
I have a great idea involving airbrushing an object, but I don't want to mess it up.
Ed
Re: What is the best way to ...
Randy Gleckler
My tactic so far has involved...
Turn a bunch of wood fishing lures and practice on them, cause if they are bad... I don't feel I've lost that much...
Buy some cheap canvas and t-shirts and when I'm done with what I want on the lures.... practice on the canvas or t-shirts.
Also.. use some of those old craps of items that are in the midst of design changes, see if you can make them worse or better....
and finally... there's a guy that has some good airbrush video's/tips on youtube Named "Airbrush Tricks" I've been browsing those and found a few good ideas to help....
Beyond that, I'd love to hear other reply's because I"ve gotten better than bad, but I wouldn't say I'm good.
Keith Tompkins
Keith Tompkins
Hi Ed, Most airbrush instruction manuals suggest learning the airbrush by creating a grid, for example, a grid of one-inch squares, then attempt a pin-point dot on the intersection of each line in the grid. That builds trigger control...dots that spread out and run aren't good. Try to create small, uniform dots. Also, uniform straight lines, especially at the beginning and end of the lines. Then, shading of cubes and spheres would follow after the dots and lines are mastered. All art stores will have books on the airbrush, which will shorten the learning curve. It's actually a lot of fun.
A dual-action brush is the best, you control both air/material with the trigger. I use a top-of-the-line Badger airbrush.
Buy Binh Pho's video, then following his suggestions get a good air brush and then lots of practice.
I was fortunate enough to assist Binh with a class and learned a lot. I had decent air brush. Not great. It still works and I've learned a lot from playing with it.
As keith said the airbrush books have some good practice techniques and I urge you to try them.
jake Niedling
Ed,
Definitely buy a dual action air brush. I have a Paasche which was around $100 at hobby lobby before their 40% coupon on any one item. Check their website for coupon. I now would like to purchase a better one made by Itawa which sells for around $160- 180.
There are some basic videos on Youtube that do help with the basics and some training techniques. The next step will be deciding what paints to use and what is the proper viscosity. Createx makes water solube arylic paints for airbrushing and I would suggest getting some of them to start with. You can always go to Walmart and buy their 99 cent bottles of arylic paints to play with.
The air brush will probably come with 3 different size needles which control the size of the spray out of the airbrush. Of course, you will need to figure out which one works best for your project. But I tend to use the smallest one most of the time.
Air pressure is another variable that you will need to play with for each paint and needle you select to use. Some where around 20 psig will be a good starting point. The higher the pressure, the more chance of over spray. The thicker the paint, the more air pressure it will usually take to spray properly. It is usually suggested to buy a small pressure regulator in addition to the one on your compressed air source. It is also recommended to add a filter to remove water from your compressed air source as well.
Good Luck and have some fun.
Jake
GREAT ANSWERS!!
Ed Moore in SW VA
Thank you very much for providing exactly what I was after. I will print them off and use them for references.
Ed
Re: GREAT ANSWERS!!
dick gerard
Take a look at the new Grex airbrushes as well. I used one at St. Paul this past June. They have a different approach. It is still a dual action airbrush. David Nittman uses them, so they must be pretty good!
Also, consider adding a compressor designed for airbrushes like the Iwata Silver Jet or the new Grex airbrush compressor. Both are nice.
