RC Helicopter's Battery Life & Turning
charlie belden
If you've been to a large mall recently, you've probably seen a guy at a little booth flying a small, remote controlled helicopter. The guy at the booth makes it looks so easy and effortless, swooping then hovering, slowly rotating the helicopter in place then rising to swoop about again.
You ask about the flight time given that these things run on a very small battery. Surprised at the short flight time of only three to five minutes, you assume that a tiny rechargeable battery is necessary for the thing to get off the ground. Only after you try and fly a little RC helicopter do you realize how "not so easy" it is to get it to do what you want it to do. And you quickly come to realize that maintaining the concentration and fine motor control required is exhausting to maintain for more than three or four minutes. Rubbing your stomach while patting your head and chewing gum - while hopping on one foot and doing a mental multiplication table - is easy by comparison.
For me at least, hollowing through a small opening is very much like flying a small RC helicopter. I can only maintain focus and tool control for a few minutes before I'm at the edge of tool control, attention span - and disaster. The farther past the tool rest I go, the shorter period of time I can spend removing wood. Passed about four or five inches I find myself clenching my jaw and making lighter and lighter cuts for about 30 seconds - which prolongs the Total Time Of Tension ( and stress).
And this is IF I'm working with DRY wood - that's fairly stable- and permits many breaks. Turning GREEN hasn't lent itself to frequent breaks - things move too much, too fast. I've sworn off madrone - green or dry - moves no matter what I don't like Beat The Clock turning.
Do YOU turn a piece beginning to end in one grueling / enjoyable session and if so, how long IS that session.
Or
Do YOU turn some, hollow some, take a break, come back to it . . .
If so, is that only with DRY wood?
Is it possible to do thin walled hollow forms - using green wood?
