Gizmo Hollowing Tool by JT Turning
Terry Gerros
Well, I've been back from SWAT and thought some of you might be interested in this new hollowing system by JT Turning Tools.
I was helping a friend of mine, Mike Smith, in his booth Century Tree Turnings. Tom Steyer's booth was close bye and his new hollowing system caught my eye. I took the opportunity to play around on the Gizmo, actually hogged the tool early in the morning before all the attendees arrived, and then had to go back and forth from Mike's booth, on my breaks, to go play with it more. Yes, that system is built like a tank, what I especially liked about it was how smoothly the articulations worked and how well it cut. Tom told me that the articulations are all ride on sealed ball bearings rather than nylon washers which are on some others. There was zero play in the articulations and it seemed to me that you could put the cutter darn near any place you wanted. The fit and finish is nothing but perfect. There are 3 bars that are available, 5/8", 3/4", and 1", all square stock. There are also 3 carbide cutter tips: 6, 8, 10 mm. At the end of the bar you will find the articulation joints are the ones found on Tom's original hollowing system, The Trans-Former System (Check out the website, jtturningtools.com). Depending on how much you are trying to undercut the rim of a hollow vessel, you may not need all those joints and they can be easily removed.
I haven't been much on carbide cutters, my Rolly Munro pretty much spends most of its time in the drawer. That being said, cutting with the Gizmo was, ummm, how should I put this.....SWEEEET. Cutting back and forth along the side of the vessel was pretty much grab free and you can hog out and do light finish cuts equally. I did find that when I went down the vessel wall and towards the middle, it would grab a little. That problem is easily resolved by starting in the middle and pulling the cutter towards you and out the vessel. Duh.
The first articulation, attached to the tool post, is machined out of one solid piece while the middle bar looks like a mini I-beam. The front piece is round stock, simply a nice hand hold for moving the bar and cutter, it fit my hand perfectly. The Gizmo is definitely beefier than the Monster tool and as far as I'm concerned beats the Elbo system hands down.
I am also happy to say I bought it! I think it was worth every penny I paid and since I bought the steady rest and extra bars, I will have to ask Tom what I actually paid for the Gizmo. There is nothing better than a well machined tool that glides as smooth as silk. Hopefully I can post a picture from SWAT of the Gizmo. I should have my grubby little hands on it by weeks end.
Re: Gizmo Hollowing Tool by JT Turning
No Photos?
charlie belden
Your description is a nice teaser. But how about some photos to go with the text?
Re: No Photos?
Terry Gerros
Hey Charlie,
I have a great photo, but can't for the life of me figure out how to post it on Woodcentral. I click the "Choose file" button to "upload embedded file", but nothing happens. I presume that is what you do to post pictures?? Any help would be great.
Regards,
Terry
Terry Gerros
Re: Photo
charlie belden
Monster on STEROIDS.
You do realize that at some point you're going to need to
a) remove it from your lathe
and
b) put it somewhere
and eventually
c) put it back on the lathe
Turning on a JET mini, I'm never tempted to try BIG turning. I get beat up enough roughing chunks of wood to shape that start out under 20 pounds ; )
I presume this thing has a laser. How's it attached and set up?
Is there a web site for this beast? I'd like to add it to my Captured Hollowing Systems Compendium. Care to do a write up for it?
Re: Photo  *LINK*
CLICK HERE CHARLIE
Re: Photo
Carol Reed, Strawberry, AZ
That's the link, Jen, but no Gizmo listed.
Re: Photo
Terry Gerros
Hey Charlie,
Sadly I do realize at some point in time I will have to take it down. It is just so cool to look at. HOWEVER, as I said earlier, I do have a Vicmarc 300 short bed which I pretty much use to turn bowls.....and well, I have to admit, I also have a Jet 1642........so, maybe I don't have to take it down????
At present, Tom does not have The Gizmo up on his website (jtturningtools.com), but I reckon he will soon.
As for writing a blurb on it, I would be more than happy to. I have written Joe Herrmann at Woodturning Design regarding submitting a review article on it and hope to hear soon if that is something that might be considered. I will keep you informed, regardless, I will be happy to put something together for you. Any chance I can get a copy of your Hollowing systems compendium?
Regards,
Terry
charlie belden
Terry:
Here's the link to what I've got so far. Put it together when I was looking for a captured system, figuring others might find it helpful when making a purchasing decision.
http://web.hypersurf.com/~charlie2/Turning/HollowingSystems/HollowingSystems1.html
I find that reviews done by new owners tend to praise what they like about the tool they bought and overlook shortcomings, in part because the review is typically done before it's had a real work out on a variety of uses. To get around that, I loan a tool to a couple of other turners in our club for a month or so. Since they have no Buyer's Bias, they tend to be a bit more objective in their evaluation. In the case of the MiniMonster, all the Non Biased testers bought their own MiniMonter units, as did several other club members.
Any idea of what the system's price tag is?
Regarding submitting a review to a magazine, find out if there's an Exclusive Rights restriction. Some magazines want to be the only one with rights to publication. Not sure if the restriction is for print media only but you might want to ask about that.
One of the shortcomings I found with systems that use interchangeable tips is Round Rod In Snug Round Hole problems. If the insert tip is held with a set screw, the set screw "dimples" the insert's shaft, making it harder to remove it or insert it later.
The MiniMonster tips COME with a machined flat on the round insert boring bar - dimple sticking problem solved. It's high speed steel cutters are out of square stock. That means that when it's slipped into the round hole in the end of the boring bar, and the set screw that holds it in place is tightened, the cutter gets oriented the same way every time - and that orientation is, by design, optimized for shearing (or scraping) wood.
With cutters that have round shafts that fit in round holes, it's up to YOU to set its orientation properly. I don't know about you, but I'm "not so good" (read "lousy") at consistency. The MiniMonster method eliminated my innate ability to screw something up ; )
I don't want this to be an ad for a tool. What I do want to do is get you thinking about things that aren't obvious - but that can make a difference between Works Out Of The Box and Works AFTER You Adapt/Modify It - or YOURSELF.
Thanks for the Link!
Don Orr
I just pulled the trigger on the "Down-n-Out" tailstock device! I've been wanting something like that for a while now.
Somebody's gotta keep the economy running. :D
Re: Captured Hollowing Systems Compendium
Terry Gerros
Hey Charlie,
I tend to agree with you regarding how new owners feel about their recent purchase. We all like to believe our purchases are sound and not spur of the moment. I will definitely keep your excellent suggestions in mind when tinkering with the Gizmo.
If memory serves me correctly, the Gizmo set runs about $439.00. I am pretty sure you can also put other bars into the unit. But will let you know once it gets here.
Terry
Terry Gerros
Charlie,
Sorry, I forgot to thank you for sending the compendium on hollowing tools.
Thank you...
Terry
