New Vase
New Vase
New Vase
Randy Gleckler
Here's a new vessel I just finished. I made sure I took my time on this, and probably could use to take another angle or two so you can see the full twist. There is a notch in the rim, and two segments that the wire wraps through curving down to make the stand. The wood is Spalted Maple I believe, I won it in a Wood drawing at a local club. Comments and critiques very welcome.
Re: New Vase
Another couple of angles;
Randy Gleckler
Re: New Vase
Re: Another couple of angles;
Ron McKinley
Only a twisted mind could come up with that! I like it. Great work! ......Ron
Re: New Vase
Re: New Vase
Don at Central Illinois
Are those two little pass throughs for the copper just glued on? I really like this, give me some ideas to try.
Re: New Vase
Re: New Vase
Randy Gleckler
Don,
Nope, they are part of the wood of the vase, I carved/drilled them all out of the same piece of wood. It was an adventure, but think it paid off.
Re: New Vase
Randy Gleckler
Ron,
I have many friends that would agree with you... Thanks for the comments :-D
Re: New Vase
Re: New Vase
Jim H
Very cool, I like the wood & copper.
Re: New Vase
Steven Antonucci
I'd like the copper to be heavier?
steven antonucci
I've looked at this a couple of times, and I certainly think you've done an impressive job on the wood, but something about the copper left me a little bit wanting. I think, in general, that you didn't do "enough" to transform it from it's original state (bare wire?)
Perhaps a couple of strands braided... a hammered pattern... flaring the end to a leaf... I'd just like to see something that doesn't make me thing "copper wire"? I also would guess that the vessel is a little bit springy, and "heavier" would imply stability.
My .02, adjusted for today's standard of living...
Steve
Re: New Vase
Re: New Vase
Randy I think the concept is interesting especially the way you have threaded it through the vessel. The wire simply looks too much like wire. I would work with the curves of the wire, possibly using less. Making the wire work with the form is going to be challenging. Maybe use 2 pieces of wire and make them flow together.
If you can find Graham Priddle's work, see how he uses the wood pieces on his pieces for support. Then work with the copper, maybe shorten it and patintate it or color it.
With your skills I'm sure you'll come up with something.
Re: New Vase
Re: I'd like the copper to be heavier?
Randy Gleckler
Steve... thanks for the critique and after reading and looking, I see what you and John are saying. Mentally in my mind I accomplished what I set out to do, but the design doesn't look finished here. Going to keep toying with this, Not sure If I can make it heavier.. but going to contemplate something... Thanks
Re: New Vase
Re: New Vase
Randy Gleckler
John,
Thanks for the suggestions and comments.. and Compliments, I appreciate them. As I just mentioned to Steve, going to give this some more thought and see if can add. The proof of concept worked, just need to finish the design I think
