Warm Work Gloves
Warm Work Gloves
Warm Work Gloves
Pete
Hi all,
I've been away from the forum for a while and had to take some time off from Turning and woodworking in general while I went thru cancer treatments last year and am just now trying to get back into it. As a side effect of the chemo I've developed Raynaud's Syndrome in both my hands (in cooler temperatures my fingers and hands hurt like hell, turn funny colors, and if they get cold enough my fingers pretty much become unusable) - with cooler temperatures coming does anyone have any recomendations for warm work gloves that would still allow me to work? I'll also definitely be adding a portable heater or two to my garage workshop to allow it to warm up a bit before going out to work, but I'd like to be prepared with some nice work gloves as well...
Thanks!
Pete
Re: Warm Work Gloves
Neil Longhenry - Rogers, MN
When I had an unheated work area I used a couple of heat lamps to keep my hands warm. I don't know if this is workable in your situation but just an idea.
Ralph Lindberg
Pete, I like Neil's idea. Frankly the idea of gloves scares the #&$^!!!! out of me. Well, I can see sometimes using fingerless gloves on the leading hand, just for protection from the chips.
I can tell you that for many businesses, a machinist wearing gloves is a violation of their safety practices.
Pete
Yeah, I didn't think that one thru, did I?? ; )
Lan Brady
Pete,
So glad you are improving and back to turning.
I can relate to the phrase- "Cold= Finger Pain"
Being concerned about having bulky gloves while turning was my concern.
I looked for alternatives as well.
1. I use a heated floor mat- Keep the feet warm and it improves the rest of your body.
2. I wear nitrile gloves- Skin tight and will tear away with any resistance.
3. I use the fingerless mechanics gloves (over the nitrile) for the palm padding.
Unfortunately you will be experimenting to find a good combination for yourself. The rewards are worth the effort.
Good Luck, Lan
Barbara Gill
I used to work in my sawmill in terribly cold weather and never did find gloves to keep my hands warm. What I have found that works are those chemical hand warmers. I slip one in each glove palm side. I have used this technique in the shop by using gloves that are on the tight side. If the warmer gets in the way I take it out and slip it down against the back of my hand.
Terry Quiram
Pete check out glooves at your nearest motorcycle shop. The full winter glooves won't work because of the bulk but I have a pair of "mid season" glooves that are great at keeping hands warm in 50 degree weather while cruising down the road.
Re: Warm Work Gloves *LINK*
Bill Turpin in WNC mountains
My wife turns, almost every day, always in Ironclad Box Handler gloves. She has tender and soft skin that prevents her from turning without gloves. She is very aware of the safety considerations. The gloves are almost like a second skin with no flaps, etc to catch. In larger sizes, the gloves are available at the big box stores for about $25. They are not insulated, but should help with auxilliary garage heat. Another reason she wears gloves is carpal tunnel syndrome. The gloves reduce some of the vibration. For her: No Gloves, No Turn!
Ironclad
Joe Dickason
I agree that the glove situation is a dangerous thought. In the rubber business it is necessary in some operations to wear gloves while running a mill. This machine is much like a double roll dough machine. The difference is that the rolls are about 3-4 ft. in diameter & 6-7 ft. long. We demand the top top side on the glove be slit. This will allow/cause the glove to come off if it happens to catch. Just a thought
Aage Rendalen
slit on top with velcro strap?
Aage Rendalen
Cutting a slit on top sounds like a good idea. A velcro strap would keep it functional; does anybody see a problem with that?
Steve Kubien
Steve Kubien
I started wearing padded fingerless gloves like those used by cyclists because of my carpal tunnel syndrome. They helped a wee bit (enough to get me through last Christmas). In February I had my right hand operated on (I'm a lefty and it wasn't as badly inflamed) and then in April I had the left done. Remarkable difference in my quality of life. No more braces when sleeping or driving more than 30 minutes and I can hold a gouge for hours at a time. Occasionally I still wear the padded gloves when I am roughing out a nasty, lumpy piece of wood.
The carpal tunnel release surgery was a godsend in my book.
My wife has bi-lateral carpal tunnel syndrome. She has had five release surgeries. All were done before she started turning. She has turned for six+ yeaars by using gloves.
Pete I'm not sure I can help with the gloves but can offer some advice. I would pick gloves the heat up with infrared heat. A heater will then be much more affective at warming your hands and let you wear thinner gloves. It's a guess but based on experience in the blacksmithing shop anything with a sort of glossy or rubber cover will really heat up. I had T shirt on one day with a super man logo stamped on the front. It would heat up to were I had to turn the shirt around to keep on working the fire. It was the infrared heat from the fire that made the emblem hot. Either that or planet Krypton was trying to contact me.
Harry Robinette
harry robinette
Pete
I have nerve problems in my rest and thumbs mainly but it's also moving into my hands. I got a Doug Thompson handle and it really helps to keep a grip on the tool. Don't know if your having a problem with your grip just thought I'd mention it. I was lucky in 1999 I got neck cancer in my vocal cords but didn't need chemo just radiation and didn't loose my voice.
Hope everything works out for you.
Jesper, Denmark
Jesper, Denmark
I am not a fan of wearing gloves arund rotating machinery - for safety reasons. But if that is the only way you can work, so be it.
The gloves used by cyclists and by sailors are without the fingertips and seem to be a good choice compromize between getting some warmth and minimizing the risk.
You might also be able to find some neoprene foam diving gloves with fingers - and cut the fingertips off. They will certainly keep both your hands and wrists warm, but be a little bulky.
Steve Kubien
Steve Kubien
I confess to having no idea what bi-lateral CTS is but 5 release surgeries?!?!?!? Wow! To date, just one on each hand for me.
Harry Robinette
harry robinette
Pete
I found these at Hobby Lobby this is all I could get from the package.
THERGONOMIC
HAND-AIDS
CONNEXXIONS INC.
hOPE THIS HELPS.
Bi-lateral=Both sides. #1 both at same day, big mistake, you are a helpless invalid. #2 left only,#3 right only, #4 left only, #5 left only. Done over ten years with four other hand surgeries thrown in for fun. 33 orthopaedic surgeries during first 35 years of marriage. 5 knees, 2 elbows, 1 ankle,5 shoulders, 1 neck...I have lost count!
Bart Leetch
Bill Turpin's the 6 million dollar man????
Joseph
Real deer skin gloves.
They make driver's and work gloves. Super comfortable, they breath, and almost become like a second skin.
Although they do look flimsy, they are surprisingly tough.
They also do tend to stretch, so make sure they are tight when you get them.
Alan Zenreich
Alan Zenreich
You might consider this as a solution
Get a pair of fingerless bicycle gloves and insert a handwarmer pack between the glove and the back of your hand (this is where the larger veins are, and carry the heat to the fingers)
At Amazon, a box of 40 pair are about $24
There are several companies making these kinds of handwarmers... I always keep some in my winter jackets and with my motorcycle gear for when I need some extra heat.
Handwarmer at Amazon
Pete
Thanks for all the advice guys. We'll see how it goes once it starts getting colder!
Pete
