Finishing the finish
Dinyar Chavda
I'm having a problem with hand-sanding down the finish (danish oil) on the inside of vessels like these, particularly at the transition points on the curves. I find it difficult to sand with progressively finer grits without leaving scratch marks, which I think are coming from the edges of the sandpaper if it contacts the wood. I've tried wrapping the sandpaper around a soft foam, but that did not help. Is there a way of doing this so that you avoid touching the edges of the paper to the wood, and only use the middle? Or any other way?
TIA
Re: Finishing the finish
Harry Robinette
harry robinette
I don't know the answer but thats a really pretty piece.
Keith Tompkins
Keith Tompkins
Hi Dinyar, Try using the flexible foam-backed sheets from Klingspoor, 3M, or Bill Bush. That should do the trick! They come in all grits. Be well, Keith
Dick Coers
Maybe switch to synthetic steel wool once you get the finish leveled.
Dinyar Chavda
I guess the place where I'm most prone to have problems is at the lower grits, like 320 or 400. Keith, I went onto the Klingspor site, and I'm not sure which items you're referring to. I also couldn't find a site for Bill Bush despite searching for it. Again, which of his products would help at these "coarser" grits?
Thanks
Katherine Kowalski
Katherine Kowalski
When I use oil to finish a piece, (Watco danish oil or Waterlox), I never start sanding below 1000 grit. In fact, on the final coat, if I choose to take the shine down a bit, I always use 4000 grit. (I prefer to use Abralon (foam-backed) pads -- they are quite soft and flexible).
Try a higher grit to start with.
Katherine
Bob Moffett
Bob Moffett
We had a demonstrator at our club recently who told us to cut darts (like in sewing)(a V) in the sandpaper and it would mold better to the curve of the bowl and reduce the edges scratching the finish.
