THE WOODRAT IS BACK!
How About Sweet Cherry?
Barbara Gill
I discovered the Sweet Cherry tree that my husband has been babying was up rooted. With my forklift I was able to lift the large roots out of the ground. I supported the main trunk while I cut it loose from the base. The base and roots are in the field and I am going back to get some chunks to rough out some large bowl blanks tomorrow when the electricity is back.
This wood looks lighter than Wild Cherry. Will it darken as much as the wild?
Re: How About Sweet Cherry?
John Veerkamp
Barbara,
Sweet Cherry in my experience will darken some with age, but it has a lot more natural color variations, especially around where branches came off and then grew over. It will split even more easily than wild cherry so get it sealed as soon as cut. It is beautiful wood. Also it doesn't have as much of the wonderful sweet smell when turned as the wild wood.
John
Thanks John
Dale Miner
Hi Barbara,
A friend had a sweet (bing) cherry go down in the spring just after leafing out. It was a pretty good sized tree, and produced a few blanks in the 12" range, as well as some smaller pieces. The owner has been pestering for a pepper mill, so 2 blanks were cut for that also. I turned two natural edge bowls about 8" with a 1/4" wall, and both cracked drying in open air in a couple days. The first peppermill blank cracked in a couple of days, so another was cut and anchorsealed on all sides. It cracked in about two weeks, end to end! Three larger bowls were roughed out from the trunk section, and all three cracked while drying (paper bag method). The tenons on the cracked roughouts had the most noticeable out of round of any wood I've seen. Most of the roughouts cracked in the bottom outside next to tenon. Some cracked in the rim, some cracked both places.
The wood itself is very pretty, lighter in color with varigations in color throughout. Not as heavy as wild cherry, or as hard. Cuts cleanly. The ends of the pieces not used for turning did darken some with exposure to sunlight, but not as much as wild cherry.
If I had more of the stuff, I would try again as it is interesting looking. I would probably double bag the roughouts, and maybe even anchor seal the endgrain quadrants. I also would try to remove virtually all of the sapwood if the blank permitted, as it seems to shrink substantially more than the heartwood (the mentioned tenons were mostly sapwood).
Good luck with the wood, let us know how it turns out.
Will we see you at Turning 2011 this fall?
Lyle Jamieson
Lyle Jamieson
Being from the Cherry capital of the world (Traverse City, Michigan), I have turned orchard (sweet) cherry and it will work wonderfully. The shrink rate is large and it is not very forgiving so I recommend turning green to finish thickness, dont mess with double turning. Do natural edges and use half the tree, dont turn with the pith in it. It will check and crack like most other fruit trees like apple and pear. Yes, it will darken
Thanks Dale and Lyle.
Barbara Gill
I cut several chunks off the base. One I ripped into two blanks. I Anchorsealed both on all 3 cut sides. I need to go to the sawmill and get the pith out of the one. If these blanks crack within the next week I will not bother turning anything out of. Wood is not an issue with me but time is. I need blanks that will make nice large salad bowls. If I can't reasonably count on my effort not being wasted I am not going to pursue it.
