Sharpening and Fire Hazard?
Stuart Johnson
Is there a danger of sparks from normal tool sharpening causing a fire? I moved my grinder over to be near the lathe and got to thinking that might not be a good idea. I try to make a stab at cleaning up after each session but have a long way to go before I'm confused with Clay and now Jennifer. I might be worrying about nothing but do have visions of smoldering chips bursting into flames at some point. I have no need for fast production type of speed so moving the grinder won't be a big deal if necessary.
Re: Sharpening and Fire Hazard?
Bill Howatt
Apparently they can. I Googled "grinder sparks starting fire" and there were various reports. I always have located my grinder away from the shavings and the like.
To add to the terror: There was a case about 10 yrs ago in Australia where a guy was grinding steel and got a loud thump, orange flash and severe burns to his hands. Apparently, the grinder had been used previously to grind aluminum and the steel and aluminum particles mixed to form thermite. Probably rare but something to keep in mind.
Bill
Steven Antonucci
Thermite?
steven antonucci
I think Thermite is a mixture of iron oxide (rust) and aluminum. While I can envision "a perfect storm" creating such condition, I'd have to see it with my own eyes to beleive it happened.
Thermite burning is an unstoppable reaction until the thermite is consumed. As much as curiousity has always poked me to try it, the little voices in my head have always talked me out of it. :)
Steve
P.S I would be very cautious about grinding a lot of steel near wood shavings. I am not concerned about the wood igniting by itself, but rather the accumulation of steel igniting, and then igniting the wood. If you've ever burned steel wool, it's pretty crazy how fast it will ignite...
Bill Neddow
I had my grinder right next to my lathe until my neighbor burned down his new barn because a spark from his grinder (he was sharpening an axe in his shop) got in a bit of straw on the floor. He lost a year's supply of hay for five horses, his entire shop, the barn, and his sister's car, which was parked inside.
I moved my grinder to the other side of my shop.
I don't know how big the risk is -- but I am not taking any chances.
I also use CBN grinding wheels now and that cuts the amount of sparking by over 90 per cent.
Bill Turpin in WNC mountains
Never make sharpening the last chore before leaving the shop for the day. Always stay around for 5 to 10 minutes for the smouldering to become noticable. If your shop is dark enough when you leave, look for glowing red spots after you turn off the lights.
Thanks - I'm moving my grinder
Stewart My grinder is at the end of the lathe and sparks can in theory hit the shavings that are frequently there. I do worry about it because I was grinding using my belt sander as the source and sparks burned a hole in the dust collector bag. Still it didn't catch on fire and it was 4 inches from where the tool was.
I have never seen sparks come out of the back of my grinder but that doesn't mean it's not happening. I do like Bill suggests. If I sharpen anything I stay in the shop for a while afterwords to make sure nothing is hot.
robo hippy
I never worried about it before. I did get some smoldering in some shavings on my bandsaw from the ceramic blocks and steel. Always keep that clear not. I have noticed that there are almost no sparks from my CBN wheels, both my older matrix style and my newer D Way. The more standard Aluminum Oxide wheels do generate more sparks.
robo hippy
Peter Charles Fagg (UK)
10 years ago I was in the habit of sharpening all my tools AFTER using them each day, until the day that I returned to my shop to collect my coffee cup and discovered a strange smell and a gentle hissing sound.
It was coming from a roll of 0000 steel wool sitting on the bench behind the grinder. Reaching out to pick it up I suffered burns to my finger tips and my thumb!
With care I stuck a gouge into the roll and took it outside and doused it with a bucket of water.
Moral:- don't be so stupid as I was!
Regards Peter.
My grinder used to be on my workbench and one day I had a piece of steel wool on the workbench burst into a violent flame. What did I do. Well I brushed it off the wooden work bench of course. Right into a pile of shavings. Fortunately I was able to stomp it out. I have tried to reproduce that incident since then and never could. maybe the steel wool I'm using has something else on it but I haven't been able to create the same flash fire.
Re: Thermite?
Powdered iron and aluminum powder actually. Good for "spot" welding among other things.
Flash fire
Jorge Casta�eda
Stuart,
A friend lost his shop to fire when he started sharpening tools after a lacquer spraying session. The sparks caused a flash fire and he was lucky to get out with only some facial hair charred. I have the grinder in a different building, very inconvenient, maybe some day I will build an enclosure for it near the lathe.
Harry Robinette
Re: Flash fire
harry robinette
I'm with most of you, sparks and wood shavings don't mix. I'm always in the shop probably at lest 15 to
30 min after using the grinder.
ihmserv
a couple of years ago, My grinders and sanders were all on the back bench got a little lax about cleaning up the fine dust from the spindle and disc sanders.
after sharpening a couple of gouges, I went back to turning.
few minutes later I start spelling smoke, took a few minutes to track it down and found a smoldering trail in the fine sawdust next to the sanders and grinder. douced the smoldering dust with the water, cleaned up the mess and moved the grinders away from the sanders the next day.
IAN
John Jordan
If you stand around 10 or 15 minutes waiting to see if you set the shop on fire. maybe you could use the time to clean up? :D
John
Joe Fleming
Joe Fleming
Maybe I'm the contrarian, but I believe it is important to keep your grinder close to your lathe. I believe that frequency of sharpening is inversely proportional to grinder distance from the lathe. Turning with dull tools is dangerous too.
My JET grinder has exhaust ports on the back of the wheel guards. I cut holes in the end of baby wipe containers so that the inverted container traps sparks out the back.
I sweep in front of the grinder frequently. Do what John says - clean up after yourself.
It doesn't hurt to keep a fire extinguisher handy in your shop either. Being prepared is the old boy scout in me.
Joe
Cats in the shop
Dave Peebles Lyons, Ohio
Stuart,
I have cats in the shop, so it is of the utmost priority that the shop is cleaned every day without fail. No chance of a fire with that thought in mind. :)
Dave
Steven Antonucci
Checked Wikipedia...it needs an oxide. *LINK*
steven antonucci
I watch a lot of Mythbusters...:D
Thermite
Re: Cats in the shop
Rich Egan
I have the same problem. I put a baby gate in the doorway to keep them out, and most of them are too fat to jump over, but I still clean up anyway. They have their ways.
I hear ya Rich,
Dave
