tuned up my thickness sander
What's this got to do with woodturning. I'm planning to use it to flatten the rings for my segmented work. I haven't done segmented work in many years now and I'm having fun relearning things. My sander is a used Performax RT. It was out of square about 3/4". Took a lot of work and some modification to two of the braces to get it square. It's now only off .008" over the 16".
I flattened some rings this morning and glued them up. I had already flattened some rings the old way using a chuck. Using the sander is way way easier. I'm excited. I'll post photos of the new piece when I get it done. which may be tomorrow.
Now I've got to build a really jury rigged dust collector for my new miter saw. That's going to take some doing.
Re: tuned up my thickness sander
Ralph Lindberg
0.008 over 16 in a great setup. Mine is about 0.01 over 12, but I would like to improve it, which takes time.
Rob Wallace
Just moisten the thinner side.....
Rob Wallace
......of the board and you'll be right-on!
:D
DE WA0RW 73, Rob
Shrinkage occurs
Rob If I moisten the thick side before sanding it will sand it thick but then shrink as it dries. Now I have to figure out how much moisture to achieve the proper shinkage. :)
matt overton
John
I have to do the same to my Delta 16/32. I just can't find the time to get far enough down my to do list before life gets in the way. I know it will be time consuming! Can't wait to see your piece. It is fun to watch you get reinvigorated on a project. Your passion inspires us all.
Got the vessel finished this morning and put the first coats of lacquer on. I had to stop and teach all day.
I 2 come over, one wanted to learn and the other wanted my help in turning something beyond his skill level. Fortunately I put the Hunter Hercules in his hand and he was able to hollow the halves most of the way with that tool and no help from me. Well once I told him to stay away from the 9 and 3 positon and work from 10 to 2. He did finish hollowing with the captured bar which again took no instruction from me other that to tell him not to cut directly into the grain but across it or downhill. That gave me time to work with the other gentleman.
I think I just took away his retirement money. He's hooked. Well he was kind of hooked before he came to me but I reeled him in and he will spending way too much money on tools, chucks, well you know the deal. Sometimes I wonder if I should have red horns and a tail before I take their sole and give it to Craft supplies. :)
