Re: OT: Computer Questions
Dave Paine
1. What type of information do I loose and need to re-enter if I delete all cookies? It depends, in many cases you will not feel any difference. In other cases, like a Wood Central cookie, the forum's will not know when you last visited, so all messages may show "new", also may not see all threads.
In sites with shopping carts, if you added items to a shopping cart and did not check out, this would be lost.
Sites with passwords where you have the browser remember the password would be lost and need to enter credentials again.
2. What happens when cache is deleted?
Not sure which cache you refer to. Normal cache is temporary memory for performance and constantly being updated. Temporary files if deleted are another "it depends". In most cases you would not feel any difference.
3. If a disc image is saved to a dvd and the hard drive crashes is the image just copied to a replacement drive or does all the software and files need to be reinstalled?
The software which creates the image is needed to re-create the image. Although the image is a single file, writing this back to a hard drive is not as simple as a file copy.
If you restore an image you should have the PC's operating system, and applications, cookies etc. back to the same state as when the image was created.
