Sphere and Femisphere do a slow dance as the slightly sloped dancefloor slowly rotates - a video can be seen at "RPRkinetics” (or just google RPRkinetics))
on YouTube - first of an envisioned series!! - critiques especially welcome
Two inherently unstabile objects on a slanted slowly rotating surface - interesting - as usual.
I'm assuming that this uses your capacitor pulsed turntable motor. Long run time, but I think with this idea, way too slow - and slightly jerky. Slow dancing is slow - but not this slow. Slow dancing is also more fluid - not jerky. Slow dancing is more continuous, not interrupted.
I think the capacitor pulsed turntable idea has interesting applications. But I don't thing in this case it works.
There's got to be a way of using small flexible mylar type solar cells to get more extended battery life - and slow but smoother turntable rotation.
Thanks for your interesting comments Charlie. I guess the piece is miss-titled if you expect real slowdance rather than its metaphor! Maybe it should just be untitled but dance is what I saw. (or HEY Charlie!! - how do you slowdance!! :-)
As a kinetic piece that one has to live beside I feel very slow and infrequent is necessary. Otherwise a fast kinetic piece, like several of yours, I think are "performance" pieces that I feel are better activated from time to time as 'requested'. This is quite a fundamental aspect of the aesthetics of kinetics!
Although the kinetics were highly sped up for the purpose of getting a video, I certainly get your point about 'jerky'. In real time one would see a tiny step every minute of so. I don't know another way to get a turntable to rotate smoothly at a rate of one rotation per hour or slower (with invisible drive!). If one reduces too much the size of the capacitor in the present system it often won't move the turntable.
Let's see. One hour = 3,600 seconds. You can tweek a servo so that it'll rotate a full 360 degrees. So that works out to 1 degree of movement every ten seconds - and servos can be controlled to 1 degree increments. A micro controller could easily be programmed to drive the servo like that. AND - you could tweek the delay parameter so you could define the elapsed time for one revolution and fine tune the movement to what you're after. In fact, the "tempo" could be programmed to change
Of course the challenge is the power source - and a way to recharge it automatically - that's small enough to hide under the turntable. Litihium Polymer batteries can hold a lot of juice in a small form factor. There are small solar panels that are as flexible as mylar that might be able to recharge the LiPo battery from the light of a spot light or two. And the whole thing could be powered on or off by that light if you added a Light Detecting Resistor. There are small LDRs that could be used unobtrusively.
You could even have the rotation rate be based on how much light is shining on the piece.
I know you've tied "aesthetics" to "slow" and see "aesthetics" and "performance" as mutually exclusive - but . . .
interesting Charlie - My microcontrollers with the best small rechargeable batteries I can find last only several days with the smallest digital motors. Power requirements are at least 100's of times the impulse system So critical is - can one actually get the tiny solar panels to recharge the batteries on an ongoing basis? That would be quite an advantage indeed. Have you seen such a system?
Given the tiny nearly imperceptible steps of my impulse system, is it worth such elaboration and added power requirements I ask myself. The impulse also serves to overcome tiny intrinsic inertia in these pieces.
Really I just see a "performance" piece as a qualitatively different aesthetic that is incompatible for a piece of art sitting permanently on a table in the living room or gallery, and not commanding attention, interfering, bothering its occupants. A few have said to me that my very quiet slow pieces already would drive them crazy!! :-)
Here's a little solar cells unit that puts out 50mA in 10 AM sunlight, 24mA in the shade or under a 20Watt compact fluorescent. The actual solar cells are only 2" x 2" but I guess they think that the bigger packaging makes it's $12 price tag more acceptable.
There's also a flexible mylar solar cell for $8. Haven't hooked it up to see how much current it puts out. This is the back of the unit which you can see is pretty flexible. 2 1/2" x 1 1/2"
Could put four of them around a pedestal supporting the rotatiing "dance floor" and get 100mA in normal room light, more under gallery spots. Larger diameter or taller pedestal could allow for 6 or 8 of these things That set up could run the micro controller and servo when there's light on the piece. A set of Lithium Polymer batteries like this one could supply powered down power when no light is falling on the cells. This one stores 120mAH and two of them are about the size of an AAA battery
I think the jerkies from the capacitor pulsed motor is a distraction. A slow but continuous rotation could keep the two "dancers" moving more fluidly.
I'm trying to reconcile kinetic yet not commanding attention, nor interfering, bothering its occupants. Art is supposed to attract attention and then provoke or evoke a response. By adding movement, it exploits the fact that our brains pick up on movement faster than edge detection, shapes or forms or color.
If something moves, and there's no one around to see it - did it move?
