Catalpa Problem
Catalpa Problem
Jim Evans
Catalpa Problem
Jim Evans
Well I learned the hard way that wet Catalpa chips will etch my tools. It turned the HSS black and it was hard to clean them up.
Does Catalpa release an acid or is it tannins?
Re: Catalpa Problem
Re: Catalpa Problem
Bill Turpin in WNC mountains
I can't imagine catalpa being hard enough to hurt anything. Any that I have turned had to be encouraged to be hard enough to take a good finish. I have turned it dry and wet
Re: Catalpa Problem
Jim Evans
Re: Catalpa Problem
Jim Evans
Bill, the problem was the wet shavings etching the steel and turning it black. This is the first time I have had this problem, but it is also the first time I have turned catalpa.
Re: Catalpa Problem
Re: Catalpa Problem
woodspinner-Harry Robinette
Jim
The acid in the wood does that just like wet Oak,Walnut ect any wood with tanic acid. Use Real Lemon Juice to take the black off your hands and tools. I keep one of those little plastic lemons on the shelf behind my lathe cause I turn allot of green wet wood. I believe it was the late Doug Barnes that told us to use it at a class at John C.Campbell Folk Art School. Doug was an outstanding turner,instructor and friend.
It's like magic how easy that black comes off with the juice.
Re: Catalpa Problem
Re: Catalpa Problem
Don Orr
Catalpa is, IMHO, a beautiful wood. It is one that does not rot easily. Whatever keeps it from rotting must be pretty strong. I do not remember having trouble with my tools discoloring, but it was quite a while ago. Definitely agree with the lemon juice for cleanup.
Re: Catalpa Problem
Jim Evans
Re: Catalpa Problem
Jim Evans
Harry, Thanks for the info. I forgot about using lemon juice or other citric acid. I used to buy citric acid to take out the rust stains in our sinks etc.
