Wisteria- can it be turned ?
B. Leathers
A friend has a couple of medium sized pecan trees to be felled. I quickly said l'd take them.One has a huge wisteria vine that is around 6" in diameter 3 feet up from ground. Has anyone turned wisteria? Is it toxic,check excessively ?I'm willing to try anything once if it doesn't bite .
Re: Wisteria- can it be turned ?
robo hippy
I saw a small vessel that a high school student turned. Lovely. Biggest problem is that it isn't a solid trunk, but a bunch of vines grown together with a lot of bark inclusions, so again, not solid. When finished, it looked like a bunch of elongated ovals. Some opened up a bit, almost like some of those candles where they use a hot knife to cut petals on the sides of.
robo hippy
Re: Wisteria- can it be turned ?  *LINK*
Wisteria - is it wood?
Yes it can but it moves more than any wood I've used when it drying from green to dry. I still have a bowl that I roughed. It was 12" and about an inch thick. It moves so much I can't put it back on the lathe. I'll have to carve it.
It starts out a beautiful green and yellow but dries to tan and dark brown.
B. Leathers
Thanks for the input.I'll probably save a section to air dry for a while and then go from there.Sounds like the smaller vines merge over the years to look like one.
