so i'm in the final stages of painting the inside of my new shop, and am wanting to think about a workbench...
those nifty ones that you can buy at woodcraft... what's so special about them? Could i get away with just a plywood top on 2x4s and get a nice woodvice?
dont plan on making furniture, but you never know what you might want to do... want to focus on small things and turning.... segmented and otherwise..
Just want to know how important a bench is, size of bench, etc....
A workbench is a must if for no other reasons than you need someplace to hold junk and your coffee cup. A couple sawhorses with a sheet of plywood will work to get you started and your bench made. If you use SketchUp there are many plans or do a Google search using "workbench plans" and you'll see everything from that sawhorse set up to what can only be described as fine furniture. But you don't need to go any further than Wood Central:
I use one like that. I use 2x4's glued together to make 4x4's. I them together with bolts similar to how beds are bolted together with a hole drilled sideways through the cross pieces that the nut fits in. I use 2 layers of plywood on top. One is flexes too much but will work. 2 glued together makes a good solid top and gives you more thickness to screw vises down.
My big workbench is the same design but has a cabinet underneath to lock things up and it gives the bench some weight. The top is a solid core door I bought at the salvage store for $5. I cut it down to a more usable size.
What is important about a bench? IMO, strength, stability and weight - and a flat top. What is so "special" about the benches at Woodcraft - they are strong, stable and they have a bit of weight. They also have holes for bench dogs and wood vises.
Do you want a "portable" bench that you can move around or do you have a dedicated shop space? If you have a dedicated space (and money is no object) then you can buy one of those nifty ones at Woodcraft.
I wouldn't get a plywood top and a wood vise. If you screw the plywood onto the frame of your bench, it might be rigid enough - but it will still have a lot of "bounce" and flex. If you choose to go a similar route, think about getting an old door. A smooth skinned (not paneled) door that is sufficiently heavy enough makes a great bench top.
If you want to do segmented turnings and carvings, you need a relatively strong, stable weighty bench with some decent vises (including a carving vise). This can be a small bench
A couple people I've known have made their benches out of southern yellow pine. They've taken 2 x 10 lumber from the building centers, let it dry for a while, ripped it to a reasonable width and length and then glued it up into a bench top. So they basically have a quarter sawn pine bench top that is maybe 3-4" in thickness. Quite heavy, very stable and strong.
Consider reading one of the many books on Workbenches such as the one by Scott Landis.
What I did for a bench top was laminate a 1" piece of plywood given to me with a 3/4" piece of hi density chip board & overlaid it with 1/4" tempered Masonite which can be replaced. It made a nice flat top not springy at all. Wrapped in Popler.
But that was more than one piece of plywood - as well as a nice really stiff piece of chipboard or MDF . My bench tops for my cabinets (NOT my workbench) are made in a similar fashion (3/4" plywood with an oak skirting and a piece of 1/4" tempered masonite as a protective layer). I can whack on it - but it is a single layer - and a little "springy" - and that was what I was referring to.
My workbench is 2 1/4" maple in the center with a 4" skirt of maple. My stretchers and legs are ash (3 1/2" square legs).
There are work benches and then there are WOODWORKER BENCHES. The former can be merely a flat surface held up off the floor with saw horses or 3x4s - a place to put stuff - maybe a metal vise bolted to a corner. The latter is a whole different beast - a giant multiple position clamp, a front and end vise, a flat reference plane for layout and assembly, a place to pound on, chop, hack and hew.
Your right JL I didn't catch that they were on top of cabinets.
You may not be able to tell it but my bench in the pic is about 3'x6' I am not real fond of the narrow topped woodworker benches. I like at least 3' deep front to back. I don't like tool trays either.
I will build a set of cabinets that will slide in under the bench on top of the rails setting side by side screwed together with a tall side on the right cabinet end & on the left cabinet end tall enough to mount a full extending drawer glide to then I'll slide a drawer or open tray in over the top of the cabinet to put most used hand tools & project drawing into. Being in two pieces with the drawers removed each cabinet will tip just slightly & slide in & when set upright & screwed together there will be more then enough room to slide the tray in on top.
I actually built one from a Norm Abrasm book. It has the holes for bench dogs and a place for a vise (which I never got around to installing). Works very well.
